Angel Eye Out!
07-09-2012, 10:06 PM | #1 |
Stay Classy
70
Rep 1,021
Angel Eye Out!
hey guys I have an angel eye out! It is the large ring on the pass side. Is there any troubleshooting to fix this?
I tried wiggling wires at connections but nothing Any help? |
07-09-2012, 10:21 PM | #2 |
Cisco661
61
Rep 974
Drives: 2006 Monaco Blue 330I
are you getting any malfunctions on your dash? you might just need to replace the AE's. good time to upgrade to something better.
2006 330i/ Monaco Blue/ ZSP/ ZPP/ I Drive/ Burl Walnut Trim/ Steptronic/ Xenon Adaptives/ Logic7/ CF Mirror Caps/ Matte Black Grills
07-10-2012, 04:09 PM | #3 |
Rep 136
07-10-2012, 08:42 PM | #4 | |
Stay Classy
70
Rep 1,021
I have not checked the bulb yet, what should I look for? |
07-10-2012, 09:14 PM | #5 |
Cisco661
61
Rep 974
Sounds like you going to have to replace the bulb. Get you some mtecs v3
07-10-2012, 09:19 PM | #6 |
Stay Classy
70
Rep 1,021
07-10-2012, 11:29 PM | #7 |
Cisco661
61
Rep 974
True. There's some on eBay for cheap and I hear they are ok. I give you the link when I get home.
07-11-2012, 12:47 AM | #8 |
Where'd my VTEC go?
481
Rep 6,067
is your inner ring working? you can't have the large outer ring out and a working inner ring because it's the same bulb...
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-11-2012, 03:57 AM | #9 |
78
Rep 2,110
07-11-2012, 05:05 AM | #10 |
25
Rep 642
Mine just died too...they took the bumper off to get at it...but I could not tell if they really needed to do that since they enter the light housing from the rear/top.
Is it necessary to remove the bumper to replace the AE bulb on a 2011 E92 LCI. (that has halogen AE for some reason...though rest of the car is LED LCI update.) |
07-11-2012, 05:51 AM | #11 |
Cisco661
61
Rep 974
check out this thread and see if it helps.
http://www.e90post.com/forums/showthread.php?t=688242
07-11-2012, 09:00 AM | #12 | |
Brotographer
88
Rep 1,741
but if you have an E92/93 LCI, I suspect the LED unit has gone bad, and that should definitely be under warranty, since the car is only a year or so old! if its not though. then its a part that will cost a few hundred bucks, you have to replace the whole LED "brick" (heatsink, 2 led emitters, and drivers) |
07-11-2012, 09:00 AM | #13 | |
Stay Classy
70
Rep 1,021
I'll see if I can post a pic It's an aftermarket AE but I do not know the brand off hand |
07-11-2012, 09:09 AM | #14 | ||
Brotographer
88
Rep 1,741
the aftermarket AE has gone bad, and needs replacement, plain and simple. if you have an e90 pre LCI, one led emitter on the aftermarket AEs are tied to each angel eye ring. so one could be dead. |
07-11-2012, 09:32 AM | #15 | |
Stay Classy
70
Rep 1,021
and that does make sense now lol Thanks! |
