car from FL
07-08-2012, 09:50 PM | #1 |
815
Rep 2,869
car from FL
I've owned my car for a little over a year now, but it was originally owned in Florida for the first 4 years of it's life...
my question is... my fan seems to act up sometimes... bad thermostat? ... does the florida heat wear on these cars more? do you guys expierence any higher rate of water pump failure's? anything else i should be aware of? (Bought my car from the BMW dealer in Pembroke Pines, Ft. Lauderdale)
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
07-10-2012, 06:31 AM | #3 |
815
Rep 2,869
yes, it has been hot the last few days (95+ the last 4 or 5 days) but that is not what is causing my fan to run more often... I have been noticing this since mid-spring. That is what really got my attention, a 70 degree day, very niec out, no hard driving, no AC,and fan is running full bore like I was just racing 10miles uphill. My car goes into the dealer in a few weeks, I want to get them to look at this but want to sound "informed" when I tell them about it with hopes of getting whatever (if there is even a problem) replaced under CPO.
07-10-2012, 08:29 AM | #4 |
Resident old fart
146
Rep 575
BMW really runs a fine line with the temps of these cars. The water thermostat is set at about 205 degrees and the car runs between 205-210 degrees as a normal course of business. On the oil side, they set the thermostat at about 245 degrees.
I constantly hear about people looking to upgrade the cooling because their vehicles are running too hot, when it is the BMW design that they run that hot. The cars could run cooler if we simply replaced the thermostats with lower temp items. While it initially disturbed me, I just ignore it now and the car seems to run fine. |
07-10-2012, 09:44 AM | #5 |
Rep 227
I moved back to Miami after being in Chicago for 7 years and just had to replace my 2008 e92's waterpump @ 70K miles. My ride was overheating and after an hour wouldn't cool off and had to get towed.
07-10-2012, 10:21 AM | #6 | |
48
Rep 932
07-10-2012, 10:35 AM | #7 |
815
Rep 2,869
Is the fan running abnormaly a sign of a failing water pump? ... does this throw any error codes the dealer could look up?
I am covered under CPO and want this replaced if this is the problem.
07-10-2012, 11:20 AM | #8 |
48
Rep 932
Yes it is. I think it does throw a code, but not one that would cause a dash light to turn on. Go to autozone, you can get your codes read for free and see if anything pops up.
07-11-2012, 02:00 PM | #9 | |
Resident old fart
146
Rep 575
Check out this thread... all new and upgraded parts and, basically, the same results. With a 205 degree thermostat, why would you expect a car to run cooler than 205? http://www.e90post.com/forums/showthread.php?t=716987 |
07-11-2012, 02:49 PM | #10 |
Rep 49
Had a 2006 325i ..2010 E92 335i & a 2007 E92 328i .. All teh water pumps crapped out at about 60k ... smh .. damn shame .. love my whips aside rom that but they do have a normal tendacy to this ..
