07-03-2012, 08:34 PM | #1 |
495
Rep 1,044
Handbrake lever cover removal?
BMW offers a nice-looking red/black parking brake handle for ZSL F30s.
Has anyone figured out how to get the factory-installed one off and how to put the accessory replacement on? Some videos I found on YouTube talking about E46 replacements talk about removing glue and re-gluing the new handle. I can't believe that would need to be done two generations later! If you know how this part comes off or have done the replacement, pix here would be appreciated. |
07-05-2012, 03:53 PM | #2 |
2815
Rep 4,939
Drives: 340i MPPSK
The handbrake assembly looks fairly straightforward according to this diagram.
Have you tried giving the handbrake lever (4) a gentle tug/twist to see if it moves? Looks like it should just slide off, although you may need to remove the gaiter (3) first. Is this the handbrake cover you mean? Looks nice. Would think that if BMW sell it as an 'accessory' then it should be relatively easy to fit (famous last words!)
Life is a state of mind |
07-05-2012, 06:13 PM | #3 | |
495
Rep 1,044
Yes, this is exactly the piece I am considering. |
07-09-2012, 09:29 AM | #4 |
25
Rep 343
OK well I popped my handbrake cover off by mistake.. Its actually pretty easy to do that.. Just pull on the piece outwards and It'll come off. The leather peice at the back is only attached on their with a plastic piece which comes off pretty easily.. Installing it back is a bitch though..
Here is the plastic tie..
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
07-09-2012, 09:30 AM | #5 | |
495
Rep 1,044
What's the issue in putting the piece back on?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
07-09-2012, 09:54 AM | #6 |
25
Rep 343
Its just tough to get in back on perfectly... I got fat fingers and am low on patience so it might just be me..
07-09-2012, 10:07 AM | #7 | |
495
Rep 1,044
It's exactly the problem of it not fitting perfectly that would make me reluctant to swap it out. I don't know why manufacturers sell accessories that aren't engineered to be easy to replace.
MY18 X3 30i:
09-15-2012, 01:14 AM | #10 |
2815
Rep 4,939
Drives: 340i MPPSK
That looks nice, any tips on how to remove/fit the parts?
Also, I don't usually go for carbon fibre in the cabin but that gear shift and surround looks rather good
10-06-2012, 02:10 PM | #11 | |
13
Rep 137
10-09-2012, 01:12 PM | #12 | |
25
Rep 343
http://www.cyberguys.com/images/prod_images/p1271a.jpg You should be able to fold the edges around the clip and then pull it over the level knob...
10-09-2012, 02:38 PM | #13 | |
13
Rep 137
10-10-2012, 09:10 PM | #14 |
42
Rep 537
Drives: 2013 335i M
I need this!
M5 with lots of goodies
11-07-2013, 11:38 AM | #15 |
Rep 1
New handbrake cover
I've just installed the red and black handbrake cover on my 335i, and here is what I learned.
Step 1. The flexible leather surround of the handbrake has to be unclipped at its WIDE end from the area around the gear lever. Pull up at the front and then unclip the handbrake cover from the transmission tunnel. Step 2. Pull the flexible leather cover all the way over the handbrake, so you can see the backside of the cover. Carefully clip off the plastic zip tie that secures the leather cover to the handbrake cover. You will need a replacement for this zip tie. Step 3. Pull off the handbrake cover. On my car it was stiff, but it does pull off towards the front of the car - you just have to be persistent. Step 4. Push on the new handbrake cover, making sure it snaps into place. Make sure also that it's the correct way up. Step 5. Re-attach the flexible leather cover in the same way it came off, that is, with the leather cover inside out. Make sure the seams on the covers align. Add the zip tie and tighten it. Note that the small end of the leather cover is attached onto the new handbrake cover groove, with the leather edge pointing to the back of the car. Step 6. Pass the wide end of the leather cover over the handbrake and, rear end first, clip back onto the transmission tunnel. That's it! |
