Restoring my headlights
07-02-2012, 04:44 PM | #1 |
535
Rep 1,873
My 2007 E90 has about 60k on it and was used by the PO as a daily driver including an Interstate-class commute, year round in the Toronto area. It's taken a bit of sandblasting in the front and the headlights were unprotected during this time (I don't understand why more people don't spend the <$100 on top notch protective film, but anyways...)
Plastic "polishes" will temporarily improve the appearance with glazes, but I'm looking for something more permanent. I have a PC ROB and yellow, white, grey pads available - probably adding orange and green to the collection too. I have a number of compounds with some new ones on the way. I also have jeweler's rouge and a wide selection of wet/dry sandpapers up to 2000 or 2500 grit. They are pitted and blasted, but there's no fogging, yellowing or UV damage. I know that wet sanding would probably fix these up perfectly but I'm worried about removing UV protection as well. I plan on putting 3M film on these lights after I "fix" them and I don't want to wetsand off some protection and then have to peel the film and be forced to polish every 3 months because they start to fog or turn yellow. I'm not sure if that's a wive's tale, but I've seen some older Bimmers in my area (like e36s) which look amazingly cared for but have foggy headlights all the time - DIY gone wrong? What's the recommendation here? Do I need to worry about fogging/yellowing if I wetsand? After I wetsand, what should I finish with? I don't believe the 3M film has any UV protection so that covered and un-covered paint ages equally, is there a "version" which has UV inhibitors available? I've attached a couple of phone pics showing their condition. Thanks, Last edited by Surly73; 07-02-2012 at 04:52 PM.. |
07-02-2012, 06:21 PM | #2 |
31
Rep 547
couple coats of a good sealant will do the job. most premium sealant are highly resistant to UV and infrared radiation. Durability is measure in months and since you will have a film over them so you should be good.
IMO... I think there are way too many owners who forget about putting a coating of protection on their headlights while they are waxing or applying sealant to their cars. i hope this helps.... Here is one. BFWD http://www.autogeek.net/blackfire-we...d-sealant.html
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
07-02-2012, 06:47 PM | #3 |
976
Rep 3,872
Drives: 330i, 135i
Mine were just like yours. I used the 3M headlight Restoration Kit and man this thing is amazing. I am very happy with results. I did mine about 2 months ago and still look great. Not sure about the UV protection but so far so good..
here is the link.. lowest price around too... Good luck! http://www.ebay.com/itm/200739283038...84.m1423.l2649 |
07-02-2012, 07:26 PM | #4 | |
535
Rep 1,873
I should have perhaps been specific enough that I'd like to try to use products I already have, since I have quite a number, instead of duplicating compounds and sandpapers by getting a kit. I'm not ruling it out though. |
07-02-2012, 07:30 PM | #5 |
360
Rep 5,052
We have several articles here (http://www.detailedimage.com/Ask-a-P...eadlight-care/) about headlight restoration with various products and techniques for different situations. A quality polish and pad can help restore many lights while a wet sanding can help those with a more severe situation. If you have any questions after reading those articles please let me know!
Greg @ DI |
07-02-2012, 08:26 PM | #6 |
87
Rep 2,854
you're going to have to look for a place that restores headlights professionally. Make sure they aren't using cheapo consumer kits like 3m or sylvania.
if they use UV lamps to cure it or it is a 2-part UV coating, they're probably legit. expect to pay between 70-100 for one headlight. This is all based on research I was doing for about a month. I had the same dilemma, except only one of my headlights was bad looking after a replacement due to a collision. Don't go with a temporary sealant or any of that garbage. |
07-03-2012, 12:14 AM | #7 |
37
Rep 359
Drives: 2011 e92 (his) 2011 e90 (hers)
I found someone on Craigslist to restore my wife's pitted and hazy e46 headlights and after the kid spent an hour sanding and polishing, and using a wax to protect them, they looked brand new. I watched him do the entire process and was blown away by his thoroughness to make them look perfect. However, a few weeks later, about half of the haziness returned. It's quite strange how that happened.
07-03-2012, 07:59 AM | #8 | ||
535
Rep 1,873
If you say 70-100, it's probably 150-200 in Canada. That's assuming I can even find a place that does it properly within an hour's drive so add time and fuel to that. If I could get a kit of the "right stuff" for even $50 I still come out ahead. Quote:
I suppose something key to find out is whether the lights are now experiencing UV damage/breakdown, or whether glazes where used during the restoration and it's just washing out and showing marking still left in the plastic. Does this E46 get a lot of sun? |
07-03-2012, 08:43 AM | #9 |
100
Rep 1,384
i did a headlight restoration on my moms nissan altima about a month ago, the protective clear coat on the lights was pitting and hazing in areas so i used the turtle wax headlight restoration kit. it takes some elbow grease to get all the sanding done properly but i followed it up with some polishing with the PC. they provide a sealant but i just ended up doing about 4 coats of the chemical guys jetseal. they came out perfect. only a month passed by but they still look brand new.
07-12-2012, 12:58 PM | #11 |
535
Rep 1,873
Well, sure, but I haven't seen anything really indicating that a durable UV resistant coating is replaced when these kits are used.
I might rather wet sand etc... with all of the stuff I already have if I could find a real, legit UV coating I could reapply at the conclusion. |
07-12-2012, 01:19 PM | #12 | |
976
Rep 3,872
Drives: 330i, 135i
07-12-2012, 01:31 PM | #13 | |
535
Rep 1,873
http://www.deltakits.com/products/4/734/ Although that looks pricey, probably something I'll have a really tough time getting in Canada, and is probably about 7 times as much as I need. Still looking. I've seen some products that require a UVA curing lamp. I bet they work great, but I don't want to have to buy the lamp for DIY. I do still plan on getting XPel so that coating doesn't need to be super durable, it just needs to work as well as the original coating at UV resistance. |
07-15-2012, 11:07 AM | #16 |
21
Rep 677
my friend has done many and once he has them wetsanded/polished/looking new, he shoots some clearcoat, but for the most part he applies opti coat, which is supposed to be a permanent sealant, and easy to apply.
07-16-2012, 05:19 AM | #17 |
11
Rep 770
Alternative product: - once both lenses have been polished to restore clarity, they should be sanded with 1500 grit finishing paper, this ensures the clear coat has a ‘key’ to enable adhesion. When you spray clear coat on the sanded lenses it fills in those light scratches and makes them clear and glossy making them look brand new. Sp*****x® (aerosol spray) is a 2K clear paint: two-component acrylic resins plus isocyanates hardener that contains UV protection
Product Application- shake aerosol can vigorously for two minutes before activating. To activate, take the red button from the cap and attach it to the pin on the bottom of the can. Put the top of the aerosol can on stable on a stable surface and push the red button firmly and press the pin into the can. Shake again for two minutes to ensure activator is thoroughly mixed with clear coat. Apply 2-3 light coats and allow 5-10 minutes between each coat. After the application of the final coat allow approximately 24 hours dry time or use an infra red (IR) drying lamp (recommended) “Headlight Restoration” - http://www.autopia.org/forum/autopia...ml#post1506615 |
07-16-2012, 08:00 AM | #18 | |||
535
Rep 1,873
I saw that one - two parts as mentioned. I think I've selected this one for my restoration. The activation of the spray can implies it's going to work once and only once. Mixing the multiple ingredients in Infinity 4.1 seems to imply to me that it will have a shelf life between uses. http://www.deltakits.com/products/4/847 I plan on removing the headlights and foglights from the car and working on a workbench instead of taping things off. I plan to work through several grades of sandpaper depending on what I find - I've got all kinds of stuff through 2500 IIRC. I plan to finish with Menzera SF4000 on an LC white pad and then top with Infinity 4.1. Soon after I'll get my 3M film on there once I'm sure that I'm happy with the results and everything is fully cured. |
07-17-2012, 12:19 AM | #20 |
21
Rep 677
google it, you will see plenty of ppl on detailing forums that use it to protect their headlights after they've been restored. here's a thread from autogeek
http://www.autogeekonline.net/forum/...eadlights.html |
07-17-2012, 03:41 AM | #21 |
11
Rep 770
In order to restore the lens back to its OEM standards a new ultra violet (UV) resistant coating must be re-applied. Use Optimum Opti-Coat™, which will provide ultra violet (UV) protection, a 2-4 µ (microns) film and a hardness of 9H (Pencil Hardness) when fully cross-linked and provides a semi-permanent coating.
An extract from the article “Headlight Restoration” |
07-17-2012, 08:12 AM | #22 |
Rep 126
3M works best never had to use it on my bmw but my older cars i've used it on all of them. I was really surprised how good they came out for $20 total for 2 cars.
