Adaptive Headlamp Control Malfunction
06-25-2012, 07:14 PM | #1 |
56
Rep 92
Just got this error message on my car today. Has anyone ever seen this? I asked my SA and he said "sounds like it needs a new stepper motor and you'll need to replace the headlight". Do i really need a new headlight for this issue? Any advice would be much appreciated.
My car is still under CPO but seems like this won't be covered. |
10-30-2012, 05:31 PM | #3 |
168
Rep 3,900
adapative headlight failure. My module went. Cost a couple grand. I had CPO though...They cover it because its not a light problem modules shot.
11-02-2012, 01:24 AM | #4 |
127
Rep 787
I have this consistently displayed on my car because I got a little moisture in my headlamp and it ruined the adaptive control system from some old angel eye mod....dealer wanted over a thousand to fix it.....u can guess what I told them... I don't need my lights to turn with the wheel that bad...a have many other things I'd like to do with an extra grand
11-02-2012, 01:43 AM | #5 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
I posted a link to a new adaptive unit in this thread. Hopefully it'll help you.
http://www.e90post.com/forums/showthread.php?t=702468
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
11-02-2012, 09:21 PM | #6 |
213
Rep 2,602
There is a module under the headlight that controls the adaptive headlights. Costs about $60 bucks used on Ebay. Try that first to rule out its failure before you spend all that dough on a new headlight.
11-20-2012, 07:08 PM | #7 |
Chief Executive
301
Rep 2,889
Drives: 2008 335xi 6spd Coupe
I got this warning light for adaptive headlights a couple weeks ago, and sure enough, while driving, the headlamps wouldn't turn ahead of me (god what spoiled brats we are!).
The code went away the next day (two weeks ago now), and hasn't returned, and the lamps are functioning fine since. My mechanic tells me the part has a history of wearing down and eventually failing, and the replacement parts are in the $850+ range (says I'll need the entire assembly). Couple questions: 1) WTF? 2) Will the lamps default to straight if it fails, and if so, is the obnoxious headlamp feature worth spending that kind of cake on? 3) Isn't there a cheaper way to fix this, like just replacing the motor on the AHL? I can't seem to find anything the above poster mentioned... My tech tells me this is a progressive issue, and it will get worse, eventually failing 100% of the time. He advised me to sit tight and wait till it completely fails. Last edited by AWD Addict; 11-20-2012 at 07:14 PM.. |
11-21-2012, 10:02 PM | #8 |
Rep 54
Got the same thing on my passenger side. My AE and turn signal works but not the headlight it self. Im not sure if ballast it self or some other thing. Still seaching for answer for 2 weeks now
11-21-2012, 10:08 PM | #9 |
Rep 54
By the way after i change my ds1 bulb with the after market one. When i turn the headlight after market bulb not working. So i put back the oem ds1 bulb and turn my headlight and oem ds1 bulb not working also. Im guessing after market china stuff fuck top my ballast thts what im thinking.
11-23-2012, 08:56 AM | #10 |
213
Rep 2,602
Look for this type of module if you have an E92:
http://www.ebay.com/itm/330815632229...84.m1438.l2649 Otherwise, use the link posted a few posts above if you have an E90.
