BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Southeast > Self Oil Change and Spark Plugs
      06-12-2012, 12:16 PM   #1
MonteB
MonteB's Avatar
18
Drives: 07 335i Black on Black
2007 335i  [0.00]
Has anyone attempetd doing this? What about the codes rest?
I'm interested in doing this next weekend the 23rd
07 335I- BLACK SAPPHIRE-BLACK INTERIOR-ALUMINIUM TRIM- 6 MT-PREMIUM-SPORT-COLD WEATHER PACKAGE-AERO KIT-RPI AIR SCOOPS- AFE Intake- JB+ -PASSPORT 9500ix
      06-12-2012, 12:25 PM   #2
obert
obert's Avatar
1781
Drives: 2013 328i
Just changed my plugs and there is nothing to reset with them, as for the oil you can reset it yourself and changing it is not that bad to do.
Lot of info on this already so you might need a flame suit on
      06-12-2012, 12:37 PM   #3
ScottB4857
Drives: 2007 335i Jet Black
Check the DIY guides for both. Plugs and oil change both easy to do with a couple "special tools" you will find in the DIY, along with the maintenance reset guides.
07 E90 335i Jet Black / Black Dakota / Sport / Performance / 19" Beyern 5's / Conti DWS / StopTech rotors / Cool Carbon / Procede / 6 spd MT
      06-12-2012, 12:55 PM   #4
MonteB
MonteB's Avatar
18
2007 335i  [0.00]
Yes thanks!
I have read the DIY's I was more or less looking for anyone that wanted to do theres as well get up a little meet and spark plug party.
      06-13-2012, 07:07 AM   #5
NiVeDh
NiVeDh's Avatar
422
Drives: '08 E90 335i, '99 E36 M3
Originally Posted by MonteB
Yes thanks!
Bring it to me. I have the tool.
      06-13-2012, 07:15 AM   #6
douwe22
dual Afe intake/ cobb/ forge dv's/ 94 oct.
douwe22's Avatar
Drives: 2008 bmw 335xi, 2008 x5 4.8i
just changed my plugs also, its easy just make sure you have the spark plug socket, i used a 14mm 12pt thin wall socket and sanded the outside wall to make it fit, lol, hopefully someone replies that has to have the same thing done as you in your area so you can together... have fun.
      06-13-2012, 08:56 AM   #7
AU335i
AU335i's Avatar
78
Drives: 2008 335i E92
not a bad DIY.
the green ring on the tip of the oil filter wouldn't come off so I just left it on there... not sure if this was a bad idea or not lol.
      06-14-2012, 07:52 AM   #8
NiVeDh
NiVeDh's Avatar
422
Originally Posted by AU335i
not a bad DIY.
Use a little pick to remove it. Technically, gaskets like that one must be replaced.
      06-14-2012, 01:43 PM   #9
ConceptE92
39
Drives: E92 M3
Spark Plugs
Hi fellow E90ers,
I was wondering if someone can confirm the correct reference for sparkplugs on an E92.
I just purchased a laser platinum set but I beleive I got the wrong kind:
PLZFR6A-11S
If someone can please confirm that would be great,
Thanks in advance,
      06-14-2012, 03:38 PM   #10
Krells
Drives: 07 335i
Originally Posted by Twinautowerke View Post
Hi fellow E90ers,
PLZFR6A-11S
Thanks in advance,
I believe those are the plugs for the non-turbo.
      06-14-2012, 10:58 PM   #11
ConceptE92
39
Drives: E92 M3
Thanks for the reply. I figured out that only bosch makes the sprks for the E92. Jumped the gun to quick on them. Already got a set though ordered today,
Thanks,
      06-15-2012, 03:04 PM   #12
AU335i
AU335i's Avatar
78
lets hope it doesn't have a negative effect for leaving the old one on haha
      06-19-2012, 07:21 AM   #13
MonteB
MonteB's Avatar
18
2007 335i  [0.00]
NiVeDh
Give me a call. I have the oil changed just need to get the spark plugs done. 774-285-9409 Monte
      07-02-2012, 07:32 PM   #14
Zeph
27
Drives: 2008 E92 335i 6MT SGM CR/BD
I have done both... well the oil a few times. Never had an issue getting the old rings off, but I may have just used a screwdriver or something. It is worth it to just buy the spark plug tool... with the SCCA discount it ends up being like maybe 30-40 bucks. If you are running decent power you will need plugs every 25k miles apparently. Also, it is good to have a "knuckle" to get to the 5th cylinder (I believe it was that one) because the STB is in the way.
Easy stuff to do, just don't jam the new plug down in there because they are easy to damage (some other guy damaged his on here). They are fine threaded so make sure they are started well and screwed most of the way in before getting out the wrench and the torque is pretty light. That BMW socket tool is spring loaded and holds the plugs really well by the way
Zeph
