How do you know what kind of tire grips better?
07-04-2007, 01:57 AM | #1 |
205
Rep 2,002
So I was looking on tire rack at several different tires for the 335.
I know the stock runflats are rated "140 A A", which is the treadwear or UTQG (Uniform Tire Quality Grade). Some of you have the Michelin Pilot Sport PS2 which is rated "220 AA A". Can someone explain that those numbers mean or what to look for when selecting a good performance tire? Thanks.
07-04-2007, 02:09 AM | #4 |
205
Rep 2,002
Why do people always complain about our stock RFTs then?
They seem to grip pretty well.
07-04-2007, 02:11 AM | #5 |
96
Rep 2,587
07-04-2007, 02:17 AM | #6 |
205
Rep 2,002
OK, but for example, the Michelin PS2 are only 12 pounds lighter (all 4 of them together). That really doesn't seem that much heavier.
07-04-2007, 02:51 AM | #7 |
14
Rep 1,137
This thread should be moved but to answer to why people complain about stock RFTs:
Because there are many RFT tires and they all are hugely different. There are excellent RFT tires and bad RFT tires within even a single manufacturer. The worst of all the manufacturers seems to be "Stock". RFTs are not heavier (compare the same RFT and non-RFT. Differences exist between the brands, not between RFT - nonRFT) RFTs have stiffer sidewalls which means better traction at the dry track in curves. |
07-04-2007, 03:04 AM | #8 |
Powered By 36DD
337
Rep 7,369
Treadwear/Traction/Temperature
For treadwear.....I've seen 110 up to 480 Traction/Temperature AA, the best, all the way to C, being the worst..... Here is the rating for my tires ---- Specifications: Nitto NT555 Treadwear: 300 Traction: A Temperature: A Speed Rating: ZR
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
07-04-2007, 03:22 AM | #10 | |
Powered By 36DD
337
Rep 7,369
for example......my treadwear is 300 doesn't mean I'll get 30,000 miles on them...... he told me to look it at this way.....if you buy a set of tires with a treadwear of 130 and a set with 340.......the set with treadwear of 340 will likely last 3 times longer.......pretty much a ratio game. my nitto nt555 has over 36,000 miles on them.....and the front looks great....probably 60% tread left.....and the rear probably another 15,000 miles left on them. If my car wasn't lowered.....the rear would still be 60% tread left too......but with the negative camber.....I had to rotate the tires inside out.....
07-04-2007, 04:20 AM | #11 |
14
Rep 1,137
The specs do not tell much. Its the traction on wet in one test. In reality there are many aspects to traction in wet such as acceleration, braking, skid pad... And you might be interested to know the traction in dry... The classification scale is wide. A and A can be quite different... The classification shows some direction if you don't know anything about the tires in question.
07-04-2007, 09:51 AM | #12 |
155
Rep 6,158
there are tires with 140 as a treadwear number with less grip than others with higher numbers
as a general rule the faster they wear out, the stickier they are but it's not always true certainly don't go much above 200 if you want a sticky tire |
07-04-2007, 10:14 AM | #13 |
148
Rep 5,389
My Mich. PS2s are great; even with PROcede, my car hardly spins the wheels/tires now; the PS2s are very sticky (for launch traction), they handle very well, and they're great in the rain.
The other non-RFTs I considered (which were less expensive than the Mich. PS2s) were the Falken FK-452s...a few ppl on here have them and like them.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
07-04-2007, 10:57 AM | #14 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
FWIW, those treadwear ratings are meaningless when you are comparing different brands of tires. This is because each tire manufacture calculates these numbers differently. And even when comparing tires from the same manufacturer, these rates can also be misleading. Only way to compare grip or longevity is to test them yourselves or read reviews from people you trust. Tire Rack has a good review/testing section for instance.
Shiv |
07-04-2007, 10:57 AM | #15 |
14
Rep 1,137
It is traction on WET. Typically UHP extreme racing whatever slicks wear out fast and the traction in wet is extremely poor. So low WET traction and low treadwear.
07-04-2007, 10:58 AM | #16 | |
14
Rep 1,137
07-04-2007, 10:58 AM | #17 | |
14
Rep 1,137
07-04-2007, 11:08 AM | #18 | |
155
Rep 6,158
many high performance summer tires carry an AA or the best possible wet traction rating many summer tires are the best possible choice in the wet the michelin PS2 (max performance summer)is rated AA for wet traction the michelin exalto A/S is an all season tire with only A for wet traction if you need good wet weather traction, max performance summer tires can be a very wise choice |
07-04-2007, 11:37 AM | #19 |
14
Rep 1,137
I was talking about sticky tires at a vastly higher dry grip performance level than PS2. E.g.
BF Goodrich 0(=zero!)-B-C Hoosier 40-C-A i.e. low traction rating and low treadwear. A good example of how misleading the ratings are is Michelin Pilot Sport Club, which nobody would want to drive on wet. 80-AA-A |
