my car is acting crazy
07-02-2007, 10:39 PM | #1 |
11
Rep 133
Ok, I've got 6mt, PROcede.
I was cruising in fourth gear and decided to hit the gas about half way. The car started to pull for a split second, but when the boost was supposed to kick in the car started stuttering and shaking and making a weird sound like frfffrrrrrrr. I let go of the gas and hit it again and it pulled just fine. This has happened to me twice over the last week, both times in fourth gear going about 45mph. I'm not throwing any codes and have had the PROcede in for about a month. Another thing I've noticed is that under normal driving conditions when I give the car a little gas just for fun the turbos spool pretty quick, but at wot I'm not getting boost until about 4500rpm's. Any input is greatly appreciated. |
07-03-2007, 12:53 AM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
You have a boost leak by the sounds of it. Did you or anyone else ever mess around with your IC piping for any reason? Either that or it could be a faulty fuel pump. Just about any other cause would induce a code of some sort.
shiv |
07-03-2007, 02:56 AM | #3 |
32
Rep 420
+1. Sounds like a leak too. I had a fuel pump problem before already and your issue doesn't immediately sound like a fuel pump problem, so I wouldn't worry about that. Check your hoses and make sure you don't have any leaks. Best of all, better to bring it to your dealer and have them check it out.
07-03-2007, 05:29 PM | #4 | |
11
Rep 133
Shiv, do you think that if the two hoses that I connected to each other from the boost solenoid could be leaking if they aren't connected tight enough? Would that even be a concern with the problem that I'm having? Thanks. |
07-03-2007, 05:36 PM | #5 | |
Moderator
270
Rep 4,481
07-03-2007, 05:50 PM | #6 | |
11
Rep 133
Ok I see what youre saying. So if that was leaking and I connect it straight to the t fitting the problem should go away? Do you think a leak there would cause the problem I'm having? |
07-03-2007, 05:58 PM | #7 |
Moderator
270
Rep 4,481
You have an unusual proplem, I think it's worth a try. Load the v1.47LBT map as well and reset the ECU ( Comms - reset ECU ) after that. BTW, do you have other mod's ?
07-03-2007, 06:06 PM | #9 |
25
Rep 458
and if the problem persists, take it to the dealership. good luck.
JB3 KW V2 i-Forged Senekas & ETC |
07-03-2007, 07:13 PM | #10 | |
11
Rep 133
Shiv I think you are right about the boost leak. I took the car out and tried to replicate the problem but was only able to replicate it once. What I did notice is that even when it's not shuttering it's not pulling smoothly. It kind of hiccups a little here and there when i give it a good amount of gas. This happens from low rpms about 2000rpm in third or fourth gear and once it's under boost i can feel the car slightly shutter at intermitent interval all the way up to redline. Do you think the solenoid hoses have something to do with the leak? Thanks |
