Aftermarket 6 spd MT Trans and Driveline
07-02-2007, 09:30 PM | #1 |
175
Rep 1,517
Drives: E92 335i coupe Black AUTO
I dont know if this is a repost or not. Since we have alot of Aftermarket Company making parts for the 335i. If we Tunning this car passing it capacity of the transmission. I do know BMW is using ZF Trans for the Trans. I was just wondering Any AfterMaket conpany offer High Preformancing 6 spd Trans? I need to see Spec on the new trans. What much MAX HP and LB /Torque? I want to see Tunning Company would like to take that?? I want to see a Aftermarket Trans pushing around 500-700 hp? 600 lb torque. I also want to see Tunning Company making 335i Driveline to handle that spec. How would much cost ?
07-02-2007, 10:01 PM | #2 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Do you think that we are really at that point yet where we need a beefier transmission? I would first look for an upgraded clutch then see if the diff and axles are up to the task before I would worry about the transmission. Just my opinion though. Based on older BMWs I really don't see this being a problem.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
07-02-2007, 10:14 PM | #3 | |
175
Rep 1,517
07-02-2007, 10:46 PM | #4 |
152
Rep 5,501
Is the MT made by Getrag? Only reason I ask is because with the 6MT Getrag on the Supra, it could handle 700hp with no problems.
2007 E92 Montego Blue 335i
07-02-2007, 11:49 PM | #5 |
Rep 301
This isn't exactly a Nissan front drive gearbox we are talking about here, I am with boosted on this the clutch and rear end are gonna give out WAY before the trans.
07-03-2007, 12:05 AM | #6 |
175
Rep 1,517
When i said stressing out the trans meaning after you did alot of modication. like add lsd, DP, Exhaust, Cold Intake, PRocede, level 2 clutch. intercooler, 104 octane mixture with 91 octane, bor out the turbo from the inside out, Changing spark plug to cold spark. bore out the piston and cylinder, and etc. i m pretty sure you need a stronger trans and driveline. When you have that much of Modification. Drivebility is not good. so you need a stronger Driveline and axle that made for high preformance... By the way, i think the ZF trans can handle 600 hp and 500-600 lb torque.
07-03-2007, 12:45 AM | #7 |
Moderator
270
Rep 4,481
07-03-2007, 12:56 AM | #8 |
335
Rep 7,719
07-03-2007, 09:10 AM | #10 |
57
Rep 879
I believe that those of us with manual trannies will be finding the limits of our trannys before the slushbox guys. I'm interested in finding out more about the tranny myself...preferrably before it explodes.
07-03-2007, 09:28 AM | #11 |
born to be turbocharged
24
Rep 1,347
LACA, lot of nice mods in plan, , but I miss one thing in your considerations (well, not only in your) - do U think the injectors will be able to give U enuff power to blow your tranny? Cuz I think they won't. Now I can be mistaken, but if I'm not, until someone finds some higher performance replacement for the recent fuel system (the whole - fule pump + injectors), all your issues are worthless... I hope this info will save U a lot of $$s and time EDIT: Clicking on this nice pix (from siemens vdo) U get a nice lil archive containing a hires version of this pic (also from siemens vdo) to check the system out in better detail. CHEERS Last edited by judec; 07-03-2007 at 09:55 AM.. |
