COBB Stage 2+ Emissions with Valet Map + DP Fix
06-04-2012, 06:13 PM | #1 |
Rep 132
I just bought a BMS dp fix for my car and wanted to know if it will pass emissions with stage0 or the valet map? Has anyone tried this? I currently have kitty-less dps, FMIC, and COBB stage 2+ tune.
06-04-2012, 06:22 PM | #3 |
Rep 132
Ok, thanks. I know the DP fix is for the "readiness", just didn't know if it had any impact on the maps that did not clear the CEL light. I guess I'll be a guinea pig if no one has tried this. I just feel better if the grease monkey inspecting my car didn't have too much fun with it
06-04-2012, 08:53 PM | #4 | |
Rep 76
06-07-2012, 10:09 AM | #7 |
79
Rep 2,396
Drives: '08 E90 335i
06-07-2012, 10:19 AM | #9 |
79
Rep 2,396
NJ's OBD testing too. Glad I don't need to spend another $90 on a DP fix that I'll use for a whole 15 mins just to get a sticker on my windshield.
06-07-2012, 10:29 AM | #11 |
79
Rep 2,396
10-24-2012, 08:46 AM | #14 |
161
Rep 7,377
if they check readyness + you have dps + stage 2 = yes
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-24-2012, 09:21 AM | #15 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
My FBO Stage 2+ passed IL emissions test back in April with the BMS DP Fix.
Here is how things look on Stage 2+ and BMS DP Fix on: Now, this is how things will look after switching back to Stage 0 and BMS DP Fix: The difference?: Notice the Catalyst Readiness is set on the second image, but not on the first.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
10-24-2012, 09:28 AM | #16 |
1121
Rep 5,396
Word of caution: The process of switching maps with Cobb AP unit also involves a procedure which clears all error codes. This is important because clearing all error codes also REMOVES all readiness codes. Its a built in process which forces the DME to perform all checks and set the necessary statuses.
What this means is: You need to drive 20-30 miles AFTER the engine reaches normal operating temperature in order for the catalytic readiness code to be set.
