downpipe rattle
06-04-2012, 11:59 AM | #1 |
15
Rep 294
downpipe rattle
Installed my VRSF downpipes a couple weeks ago and now I've been noticing a rattle.
It's definitely not a waste gate rattle because it only happens when I hit a bump or drive over some of those painted lines. The sound seems like its coming right below the center console from inside the car, I took the plastic cover thing off the bottom and inspected the downpipes and noticed that they we're very close together where they attach to the exhaust. Not sure how to fix the rattle or if the sound is even coming from there. I've noticed there is also several other spots that could be causing this noise. Anyone have experience with their downpipes rattling? Looking for some help here.
JB4 and other stuff
06-04-2012, 12:17 PM | #2 |
194
Rep 6,136
It could be the DP rattling against the heat shield. I would reccomend getting back under there, bending the heat shield away a little, and attempt to reposition the DP a little
06-04-2012, 12:18 PM | #3 |
79
Rep 2,396
Drives: '08 E90 335i
I have VRSF DPs and we the fitment on the one closer to the trans was a PITA. Basically needed 3 people to install that one w/o having any rubbing: 2 people held the DP in place while the other 1 bolted it all together. Huge headache, but the mech said these were nothing compared to the frustration he got w/ Fabspeed's. ARs & Macht Schnell he said might as well bes old by BMW -- Perfect fit.
06-04-2012, 12:19 PM | #4 |
15
Rep 294
Thanks, I think I remember the heat shield from install. Is the the PITA one to remove that has two screws on the top side?
JB4 and other stuff
06-04-2012, 01:50 PM | #5 | |
dat boost doe
238
Rep 1,823
its just that installing any downpipes, skews the viewpoint, when its difficult every downpipe is shitty quality lol.
06-04-2012, 02:03 PM | #6 |
79
Rep 2,396
^^This is true... A shitty install changes peoples opinion very quickly. In the end it worked out really well, there was plenty of space between the DPs + heatshield/trans. Car sounds phenomenal now, just wish it wasn't misfiring so I could actually drive it
06-04-2012, 02:11 PM | #7 |
dat boost doe
238
Rep 1,823
LOL, i forgot you are misfiring too
06-04-2012, 02:23 PM | #8 |
DIYER
614
Rep 5,521
Wonder if thisis the rattle I have?? I really don't think it is Wastegate rattle. It only happend on light acceleration, from 2,500 to 3,000. Doesn't happen at idle or deceleration. I have AR kittyless pipes that fit perfect. I am thinking maybe the heat shield on the brakes have a rock in it.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
06-04-2012, 02:38 PM | #9 |
151
Rep 1,677
On the stock DPs, there's a hanger where the DPs bolt on to, but the hanger isn't welded on the DPs. Using aftermarket DPs can get very close to this hanger so what I did was bend it to have more clearance.
06-04-2012, 02:41 PM | #10 |
79
Rep 2,396
06-04-2012, 02:45 PM | #11 | |
dat boost doe
238
Rep 1,823
what codes do you have?
06-04-2012, 02:48 PM | #12 |
DIYER
614
Rep 5,521
May look into this, great info
06-04-2012, 03:06 PM | #13 |
79
Rep 2,396
Running COBB Stage 2+FMIC Sport, I got:
Taking the car to Bimmer Clinic in Elizabeth Wednesday morning -- Hopefully between spark plugs & a broken o2 sensor it'll be problem free Wednesday afternoon Last edited by benzy89; 06-05-2012 at 11:43 AM.. |
06-04-2012, 03:45 PM | #14 | |
dat boost doe
238
Rep 1,823
im guessing also, that this might be injectors? tell me what they say. ps, they are the one on rt9?
06-04-2012, 08:31 PM | #15 |
79
Rep 2,396
Took the car out to a friend whos a BMW mechanic, think he just installed the sensor backwards (I'm getting lots of lambda, running rich codes). I bought plugs just in case but I'll let you know how it goes/what Bimmer Clinic is like. Hopefully I'll be in a lot better mood after they get their hands on the car.
06-05-2012, 02:01 AM | #16 |
39
Rep 315
I had issues with my ar designs DP. After a few hundred KM's, ended up putting the car back on the hoist, loosening the one flange and repositioning it.
I had it rattling on a chunk of the transmission. We now have a good quarter inch or so of clearance. If it's an issue again, we'll be grinding down that part of the tranny. |
06-05-2012, 08:11 AM | #17 | |
dat boost doe
238
Rep 1,823
06-05-2012, 08:50 AM | #18 | |
79
Rep 2,396
I'll let you know how it goes tomorrow (hopefully not an expensive repair). |
06-05-2012, 11:32 AM | #19 | |
DIYER
614
Rep 5,521
06-05-2012, 11:37 AM | #20 | |
dat boost doe
238
Rep 1,823
06-05-2012, 11:40 AM | #21 |
15
Rep 294
checked the downpipes yesterday and one of the clamps that hold the down pipe to the turbo was SUPER loose. I tightened it all the way with a little too much ease. I'm thinking the clamp may have broken and the down pipe is coming loose. Will investigate more this weekend.
JB4 and other stuff
06-05-2012, 11:47 AM | #22 |
79
Rep 2,396
