Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Datalogging WGDC and boost leaks
      06-04-2012, 11:00 AM   #1
rader1
70
Drives: Cobb Stage 2+ 135i
Hey guys, I'm working on a data logging DIY and I need some help. If anyone has a data log of of their WGDCs when they had a boost leak I would greatly appreciate it if you would email me the CSV file( allenrader1@Gmail.com )
Sorry to interrupt the "what intake/exhaust/FMIC/rasp free exhaust should I order?" thread pattern.
      06-04-2012, 11:07 AM   #2
tofu-
87
Drives: 335i Jet Black/Coral Red
quickest and best solution would to be to just send them over to terry. if he says everything is ok, you'll then have your own baseline to work from if future problems arise.
      06-04-2012, 11:12 AM   #3
rader1
70
No, i don't have a boost leak and never have. That's the problem. I need logs from a couple people of their WGDCs when they had a boost leak so I can incorporate it into a DIY on data logging and data interpretation.
      06-04-2012, 11:12 AM   #4
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
If pwm maxes out straight away you got a leak.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      06-04-2012, 11:17 AM   #5
tofu-
87
ah i see what you mean. i read your first post too fast
      06-04-2012, 11:22 AM   #6
rader1
70
Its all good
      06-04-2012, 11:29 AM   #7
jpsimon
Team Zissou
jpsimon's Avatar
3065
Drives: 2022 AWD M3 Comp - SMB
rader, here are a couple datalogs when I was diagnosing my boost leak. along with WGDC i have boost set point vs. actual boost... and if you want any more info the boost leak was where the charge pipe meets up to the intake manifold.
      06-04-2012, 11:50 AM   #8
rader1
70
Thank you, sir!
