Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Car died, codes inside *HELP!*
      06-02-2012, 09:57 AM   #1
Lulz_M3
33
Drives: AW 335i 6MT
Exclamation Car died, codes inside *HELP!*
Last night i was driving my car with no issues, parked it for 45 minutes after a game of putt-putt golf and it wont start. Prior to this i have had no issues with the car whatsoever. Flashed the car back to stock to ensure it wasn't tune related, but i am getting the following codes still with no start:
P3100 - No Cobb description, but I believe this is a generic code for a limp mode event
P2A9A - Crankshaft - inlet camshaft, correlation
P2A9B - Crankshaft- exhaust camshaft, correlation
P2ACB - DME main relay control
P2ACC - DME main relay, diagnosis for a condition shutdown test
P2A9E - Intake camshaft, synchronization
P2A9F - Outlet camshaft, synchronization
So basically at this point i had the car towed to my house and i am going through the fuse box behind the glovebox and will check the fuses in the DME next. Anyone seen these codes or have these issues before?
      06-02-2012, 10:15 AM   #2
Lulz_M3
33
Drives: AW 335i 6MT
Fixed, main relay was either loose or going bad. Gonna pick up a spare just in case.
      06-02-2012, 10:35 AM   #3
Ilma
184
Drives: 2008 135i
Good for you!
Was that relay located on the fuse panel behind the glove box?
      06-02-2012, 11:02 AM   #4
Lulz_M3
33
Drives: AW 335i 6MT
Yes it's on the right side of the fuse box behind the glove box. Noticed it was very warm when I put my hand near it. Took it off and inspected it, reinstalled, car fired right up.
      06-02-2012, 11:24 AM   #5
Boco335iXdriveSE
Drives: 335i Xdrive Special Edition
That is good to know! Thank you for sharing!
      06-02-2012, 05:35 PM   #6
E30M3Driver
E30M3Driver's Avatar
37
Drives: 2021 M2C, 97 M3
2007 BMW 335i  [8.00]
1989 BMW M3  [8.20]
If you continue to have problems, you may need to check out for corrosion at the junction box on the main power cable that goes to the battery. It is in the same location and exhibits the same symptoms. You may have just got lucky with jiggling the relay. There is an SIB out on the cable/Junction box.
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler |
      06-02-2012, 05:42 PM   #7
Lulz_M3
33
Drives: AW 335i 6MT
I actually replaced the fuse box and cable about a month ago. I am unsure if I left the relay loose while transferring to the new board or if the relay is actually going bad.
