06-01-2012, 08:46 AM | #1 |
26
Rep 72
What RPM do you shift at?
For all the 6MT F30 owners, what RPMs do you shift at?
Since the first several gears are so "tall", I'm finding gear 5 to be obsolete when accelerating from 0 to 50 mph. My casual shifting pattern: 1st to 2nd: 3200 RPM 2nd to 3rd: 3000 RPM 3rd to 4th: 2500 RPM 4th to 6th: 3000 RPM |
06-01-2012, 09:53 AM | #5 |
453
Rep 2,148
Drives: F87 M2 BSM MT
Wait I thought the car would stall if you shift before 7000RPM....LOL
06-05-2012, 01:17 PM | #6 | |
892
Rep 7,047
The 328i MT has a "short"/high number final drive-3.91, and 5th and 6th are over drive gears. In the 335i, 1 through 5 are drive gears, and 6th is an over drive. Final drive ratio is "taller"/lower number-3.23 in the 335i MT. That quite short final drive in the 328i is what gives the 328i MT very good 0-60 acceleration. With 5th and 6th being over drive gears, there has to be a pretty good drop between 4th and 5th, more so from 4th to 6th.. I can see why you don't really need 5th. By the time you accelerated between 1 through 4, you're probably looking for best over drive as you're at speed by then. Give how tall 6th is, I wouldn't use it until around 55-60mph. When you go to 6th at 50mph, what rpm is the engine at? Just curious, how fast is the car moving at the top of 2nd, at red line? |
06-05-2012, 01:31 PM | #7 | |
453
Rep 2,148
06-05-2012, 02:37 PM | #8 |
309
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
What speed is the 335i 6MT doing at the end of 4th? My E90 330d would be doing about 120mph.
It was geared for 170mph ish and does about 4500rpm in 6th at 155mph.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
06-05-2012, 02:48 PM | #9 | |
26
Rep 72
The car has so much low end torque, this is not a problem for casual driving. With such a good engine, BMW could have done okay with just 5 gears. I guess the 6th is useful when I'm hitting 150 mph going to get my groceries. |
06-05-2012, 04:05 PM | #10 |
211
Rep 3,288
Drives: anything given a chance
4267rpm for each gear without fail.
06-05-2012, 04:10 PM | #11 |
29
Rep 784
My 335i 6MT is still on the boat to the US but IIRC, it was turning about 4500rpm at 200kph (~125 mph).
06-05-2012, 05:28 PM | #12 | |
6659
Rep 15,858
Years back with the 1:1 top gear ratio, often the gearbox had an option to have an overdrive unit fitted on the rear of the box, to give a higher 'fifth' output ratio. (something like a 1:1.1 ratio). Laycock was one common overdrive unit used in the UK, and you had a switch, often in the top of the gear knob, to switch the overdrive ratio into gear. I had an overdive unit on my Triumph Dolomite Sprint, (1976) gave 'half a gear' between 3rd and 4th, and an overdrive on 4th gear. Incidentally it was a clutchless operation. Now we often have, as said, two overdrive ratios in a standard 6-speed gearbox. HighlandPete |
06-05-2012, 07:06 PM | #13 |
[Versatile]
380
Rep 1,683
Shift @ redline bro.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. |
06-05-2012, 09:04 PM | #14 | |
892
Rep 7,047
With 5th and 6th being over drive, 150mph just brings the rpm way down for a relaxed 150mph experience. |
06-06-2012, 07:20 AM | #16 |
S0THPAW
8736
Rep 7,847
Yesterday I hit 110kmh(68.365444 mph, this is a tech thread so I want to look like Einstein too ) in second gear...
7000 in 4th gear is about > 200/210kmh(?) I never look at the speedometre when I want to go fast. I watch the road ahead(and my '6' for interceptors/cops whatever) Cheers Robin |
