BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > How To: Install Dashboard Mount
      06-01-2012, 02:35 AM   #1
iBeech
iBeech's Avatar
England
109
Drives: BMW 520D F11 2015
Post
So here is the first how to for the F20 in this forum, from what i can see...
The task: Fit a dashboard mount to the F20
Why: Because i hate suction / vent mounts for my phone- the either leave a mess, or block ventilation!
What do i need?:
  1. Dashboard mount http://www.dashmount.co.uk/index.php...11i-Drive.html
  2. Phone mount (attaches to dashmount and holds phone) http://www.brodit.com/product.html?id=514164
  3. STAR T20 Screwdriver
How:
  1. Step 1: Remove the centre console vents
    In this step, which is not as easy as a certain youtube video would suggest, we remove the center console vents. I did this by gripping the top right of the vent and getting my fingers under and unsnapping it, then i ran my fingers along to unsnap the left hand side. As seen below:
    I then ran my fingers down from the leftside to finally unclip the vents:
    At this point you can safely rest the vents on the centre console, it wont damage or scratch anything
  2. Step 2: Remove the passenger side T20 (STAR) screw
    Below you can see the screw which needs removing, this was simple, although a little effort was required- so make sure you use the correct bit, or you'll bald the head.
  3. Step 3: Insert the dashboad mount
    At this stage, i was a little worried as i couldnt figure out how to get the mount in. Turns out you simply need to slide it down between the dashboard and the CD unit as shown in the image below. ensure you align the screw hole with the screw hole in the dash
  4. Step 4: Reassemble
    Reassemble by screwing the T20 screw back in (nice and tight so everything comes together), and snap the vents back onto the dash
  5. Step 5: Attach your chosen phone bracket
    I used my brodit dock from my previous car, but you can attach whatever you wish. Any brodit dock works with this solution. The great thing about brodits is that its on a cylinder adjustable- so it can be rotated any direction to suit your needs
  6. Step 5: Admire work
    Congratulations, you now have a convenient way to access your phone. I'll post up how i routed my USB cable to the arm rest, if i ever get around to it:
    UPDATE: I wrote the USB routing guide: http://f20.1addicts.com/forums/showt...6#post12113876
      06-01-2012, 09:43 AM   #2
sdk2007
Drives: F20 M Sport - Estoril Blue
Very handy ):
Is there any danger of snapping the clips when pulling the vents off?
      06-01-2012, 10:28 AM   #3
iBeech
iBeech's Avatar
England
109
Originally Posted by sdk2007 View Post
Very handy ):
dont think so- it looks pretty solid to me
      06-01-2012, 11:37 AM   #4
Patrick BMW
Patrick BMW's Avatar
Drives: Jeep Wrangler Rubicon
2016 BMW 430iAM-Sport  [0.00]
2012 125i  [9.00]
What a good write up. Photos are really excellent and makes a great MUST READ if I get around to it....though I will do it in my jeep now just to get the practice in!
      06-01-2012, 02:26 PM   #5
iBeech
iBeech's Avatar
England
109
Thank you! I shall post up anything else I do in similar format
      06-02-2012, 01:14 AM   #6
NeilC
Drives: 116ED
I just installed a Brodit vent mount. It literally took 30 seconds, is very stable, and is in a great position (between the steering wheel and iDrive screen).
I use to have my iPhone mounted left of the vents, but found it too distracting looking that far left each time (I use TomTom on the iPhone).
Now it is right in my line of sight.
Neil
      06-02-2012, 02:35 AM   #7
Fanis
Fanis's Avatar
Greece
53
Drives: 116i (F20) Auto
iBeech, all your DIY are excellent...keep it up mate!
2011- : BMW 116i (F20)
2009-11: BMW Z4 2.5si (E85)
2007-09: Mini Cooper S (R56)
2005-07: BMW 325ti (E46)
2004-05: BMW 318i (E36)
      06-13-2012, 03:44 AM   #8
iBeech
iBeech's Avatar
England
109
Thanks Fanis as long as i keep doing things to my car, i'll document and share
      07-02-2012, 03:38 PM   #9
nilo
Belgium
Drives: BMW 118d F20 M Sport
Do you know if it's possible to mount the dashboard mount you use on the right side of the console (you know, for left steering cars)? I use a Brodit Proclip in my current car and would love to have something similar in my F20.
Thanks!
      07-02-2012, 03:52 PM   #10
iBeech
iBeech's Avatar
England
109
Thanks!
Yes- just do the same but on the opposite side!
      07-20-2012, 08:21 AM   #11
GSH
Drives: 118d Sport
Thanks for this guide, really handy!
      11-27-2012, 12:48 AM   #12
cozza
///Mthusiast
cozza's Avatar
Australia
135
Drives: M135i (March delivery)
A company in Australia called Hold My Phone has 2 options that are click on, and don't require any dismantling of the dash:
http://www.holdmyphone.com.au/1841-1...tre-Mount.html
http://www.holdmyphone.com.au/1841-1...and-Mount.html
You can also select a bracket for your specific device.
///M135i: AUTO | ALPINE WHITE | CORAL RED LEATHER | HEATED SEATS | SUNROOF | NAV | DAB TUNER | HARMAN KARDON | PERFORMANCE BITS 'N' PIECES
      02-12-2013, 04:07 AM   #13
Benstermin
Life in Oversteer
Benstermin's Avatar
Drives: F20 125i M Sport
Thats the Brodit solution.
      04-03-2013, 12:50 AM   #14
mbrogden
Drives: BMW 114i SPORT F20
thanks
      04-25-2013, 03:49 AM   #15
SKTAN
Drives: buick
good job, thank you for the explainantion.
      05-20-2013, 09:20 AM   #16
dayzer
Ireland
Drives: 116D
Great Post - Once my car is delivered, I will be doing the above
      05-27-2013, 10:46 AM   #17
matg
Drives: M2
Great guide, thanks for posting.
      09-11-2013, 03:26 PM   #18
rxavier
Drives: 118d sport
Thankyou
part just arrived so will be fitting this weekend. Have had the car for a week now. Love the way it drives, but a few niggles that hopefully the dealer will sort out...
      03-24-2019, 10:58 AM   #19
EE60
34
Drives: 2015 M235i vert
Awesome Post
I just finished installing an iPro2 MFI using this and your other post.
Thanks so much
      04-13-2023, 12:01 PM   #20
cururu
Drives: BMW 120i F20
I would like so much to see the pictures...
1addicts
