PWM: WW Tank to Trunk Mount Compatibility
05-31-2012, 08:12 PM | #1 |
40
Rep 957
I am still currently storing my methanol up front in the WW tank. I would like to get this squared away and relocate the pump and reservoir. I have contacted a great vendor on here, but even he was unsure of what would be compatible. I quite frankly am unsure how any tank would necessarily be incompatible, but if this is the case, could others please chime in and let me know what are some of the favored methanol reservoirs and why you went with which. I understand i want the tank above the pump first off.
This is my first time having methanol in a vehicle so the PWM install was my first. I will have to run lines to the trunk, which is another question. Where along the car do people commonly run the line to the trunk. Yes, I'm basically asking the path in which i should route the line and what to secure them with. Relocating the pump to the trunk means also running the wires from the meth harness all the way back to the trunk now as well. Did others just get connectors of a sort and run them on back? Do you run the wires with the methanol line in one neat bundle? Thanks guys, while I've had the PWM kit for several months, i am still new to methanol, the equipment, and set ups outside the realm of the standard PWM set up.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
05-31-2012, 08:50 PM | #2 |
441
Rep 18,331
If you need some ideas how to run it, it doesnt get better DIY then this my friend. I have used it like the bible!
FBIS thread on methanol injection http://www.e90post.com/forums/showthread.php?t=297336 |
05-31-2012, 09:07 PM | #3 | |
307
Rep 5,175
05-31-2012, 11:26 PM | #4 |
184
Rep 2,841
For the PWM kit, I'm speculating that all you have to do to move the pump to the trunk is cut the red and black power/ground lines in the engine bay going to the pump and splice in two extension cables over to the trunk.
Leave the Fast Acting Valve where it is in the engine bay and just run the meth feed line from the pump in the trunk directly into the inlet port on the FAV. Mount your new meth tank in the trunk and run the tank meth line to the inlet side of the pump. If you get an in-tank filter then you could even elliminate the inline filter and just run one solid straight feed line to the FAV thus eliminating another variable in the system. Seems to me that all the other parts of the wiring harness will simply stay where they are in the engne bay. |
06-02-2012, 01:18 AM | #5 |
47
Rep 731
guys doesn't it make more sense to keep the pump under the hood? its not gravity fed, so technically does not need to be in the trunk.
Everyone just says its better because its cooler temps in the trunk, but the pump has been working just fine under the hood, its the tank everyone's having issues with. I want to see some members do just a tank relocate, I personally do not want to splice and run harness wires from trunk to the ecu. |
06-02-2012, 08:00 AM | #6 | |
42
Rep 659
06-02-2012, 08:47 AM | #7 | |
184
Rep 2,841
If you get air in a line that long.....it may be difficult for the pump to draw fluid and you won't have the benefit of a ww pump to help you purge the air. Simpler to just have the tank gravity feed the pump. Once the meth hits the pump pressure ramps up greatly and will be easily pushed along to the engine bay. If you are going to all the trouble to relocate the tank in the trunk, then why be lazy and not relocate the pump too? It's just another two wires to connect to the pump and you can run them along the same route as your meth line. |
06-02-2012, 09:06 AM | #8 |
42
Rep 659
yeah i read the disclaimer about not great at sucking lol that's why i kept my option open. moving the pump isn't that hard, but there is another concern having the pump so far away from the power tap. the pwm system also have the pump, solenoid, and flow sensor all bundled in a neat package so i just hate to take it apart unless i start having problem with flow.
06-02-2012, 10:03 AM | #9 | |
184
Rep 2,841
Much easier than I thought. You just cut the red and black power/ground lines running to the pump itself - tap them and extend the lines to the trunk and connect them to the pump there. Circuit is still the same....you have just run longer wires. Undo the three bolts holding the pump to the metal bracket and away you go. Don't need to mess with anything else. You can leave the Fast Acting Valve attached to the metal bracket that came with the kit along with all the existing relays and wiring harness connections. Boost trip switch remains connected to the diverter valves in the engine bay. In fact the FAV will act as a solenoid and prevent fluid from being drawn backwards towards the tank. You just run a single long meth line from the pump in the trunk to the inlet side of the FAV. Have I missed anything? |
06-02-2012, 10:07 AM | #10 |
15
Rep 368
Might be a noob question. But doesn't the distance from the pump to the check valve have something to do with how well the system works? Relocating the pump and leaving the check valve leaves everything unchanged? I remember my old cooling ,it's kit in my evo x specifically wanted the pump check valve and flow sensor all close to each other?
06-02-2012, 10:19 AM | #11 | |
184
Rep 2,841
I know that having the pump higher than your tank is also not considered optimal, but it seems to work OK in a WW setup because you can power purge any air in the line with the washer pump. If you have one single meth line from the trunk pump to the valve in the engine bay, then the only source of air entering the lines would be from the injector nozzles themselves, since they are open to atmosphere. Gravity will siphon meth out of them and let air into the lines. So in my mind, the closer that check valve is to the source of air, the better since it should prevent fluid from dripping out and being replaced with air. I would rather purge a couple of inches of air in my line near the nozzles than purging air all the way back to a check valve in the trunk. But I could be wrong. |
06-02-2012, 11:27 AM | #12 |
Chump
Rep 173
Has anyone thought to just take out the WW tank and dedicate it to meth by modifying it?
2009 e90 LCI Blacked Out Space Gray - Vishnu Procede 2.5 w/9-10 Aggressive Map Stg2 - PWM Meth (80%) - BMS DCI - VRSF Intercooler - VRSF Downpipes - HKS Cat-back Exhaust
06-02-2012, 11:45 AM | #13 | |
184
Rep 2,841
But at the sacrifice of your wiper system. OK for those folks who live in warm climates.....but for those with snow it is not an option. Road smear and salt residue will completely obscure your vision, so having a working wiper/washer system is just another safety area that you would give up for the sake of a meth tank in the engine bay. |
06-02-2012, 12:58 PM | #14 |
40
Rep 957
my mind is a clusterfuck right now. sheesh i dont know what to do, what i should relocate bla bla
06-02-2012, 09:14 PM | #15 |
42
Rep 659
06-03-2012, 10:51 AM | #16 |
Rep 50
06-03-2012, 03:04 PM | #17 |
40
Rep 957
LOFL haha
06-03-2012, 03:57 PM | #18 |
49
Rep 770
I just moved my pump to my trunk and installed a tank back there..was very simple.. A friend of mine came up with a very simple way to route all the wires etc..so he did it for me last night and it really didnt take to long..
06-03-2012, 05:51 PM | #20 |
346
Rep 2,396
I just completed the install last night.
Get Snow Performance 2.5gal tank from eBay that comes with its own line and tank was already pre-tapped. The tank fits perfectly over the amplifier cover. I just put a big glob of silicone between the tank and cover and it holds up nicely. No ugly straps or bolts. I completely removed the Vishnu bracket and attached the solenoid, relay and all the wiring to the DS strut tower Ran the power and meth line through the interior. Jacking up the car was not an option at the time. The pump sits sideways under the trunk liner strapped in one of those half-dome openings with an aluminum strap that came with the tank. |
06-03-2012, 07:28 PM | #22 | |
292
Rep 2,898
Neil |
