Converting Vishnu PWM kit to use SS braided hoses and trunk mounted tank
05-31-2012, 03:58 AM | #1 |
Rep 56
Hi Guys,
I have the PWM kit with the older pump. With the recent increase in reported fires, I have decided to go trunk mount. I am deciding between the following tanks. 1. http://www.alcoholinjectionsystems.c...duct_info.html 2. http://www.alcoholinjectionsystems.c...duct_info.html 3. http://www.howertonengineering.net/p...Enclosure.html Option 1 has a neat and effective sight gauge, options 2 and 3 enclose the pump for a cleaner install. Options 1 and 2 seem safer than option 3 in terms of build quality and the fuel cell caps. I'm currently leaning towards options 1 or 2. Regardless, I would go with any of the above options if they can work with the Vishnu PWM kit, stainless steel braided lines and better quality / heavy duty fittings. From what I've read, the Aquamist pump does not play well with AN fittings? Has anyone had any experience converting this way and can point me to the correct, compatible hoses and fittings (ie. What hoses to use and what size fittings are needed)? Safety and reliability are more importance factors than pricing. Thanks! |
05-31-2012, 12:17 PM | #2 |
Chump
Rep 173
I like option 2. I also have the Vishnu PWM (older pump) and I'd love to get this setup. It'd be nice to hear from someone with experience exactly what fittings to get, etc.
I took a look at everything and I'd assume we could get: 1. http://www.alcoholinjectionsystems.c...duct_info.html 2. http://www.alcoholinjectionsystems.c...duct_info.html 3. http://www.alcoholinjectionsystems.c...c42/index.html (Various push fittings to down convert to the standard black tubing that we have already) Anyone have any other opinions? This seems expensive, but a solid route nonetheless.
2009 e90 LCI Blacked Out Space Gray - Vishnu Procede 2.5 w/9-10 Aggressive Map Stg2 - PWM Meth (80%) - BMS DCI - VRSF Intercooler - VRSF Downpipes - HKS Cat-back Exhaust
05-31-2012, 01:03 PM | #3 |
46
Rep 1,145
I'm thinking about getting this one:
https://www.coolingmist.com/pagedisp...x?pid=Protank1 Gravity fed ftw! |
05-31-2012, 01:07 PM | #4 | |
boom
12
Rep 598
05-31-2012, 01:08 PM | #5 |
46
Rep 1,145
Does it come with tubing or did you have to buy that separately? If so, how many feet do we need to run this from the trunk to our CP?
05-31-2012, 01:16 PM | #6 | |
boom
12
Rep 598
Came with what looks like 20 ft of tubing but you won't need all of it, a check valve, 2 90 degree push-in elbows, the tank and some screws. To mount the pump in there you need to have/make a metal bracket, mine is a Cooling Mist pump so I had the bracket already (has 4 little rubber feet on it). |
05-31-2012, 01:20 PM | #7 | |
47
Rep 731
I also am in the same position as you with the older pump.
Planning on draining my WW tank today and planning to relocate tank, really looking forward to seeing other members setups... Quote:
05-31-2012, 01:24 PM | #8 | |
47
Rep 731
we should be able to leave everything as-is and just setup a new tank/line. Is there a reason why gravity fed is better? (sorry first meth kit here still learning) |
05-31-2012, 01:24 PM | #9 |
Power is nothing without control
33
Rep 762
Guys, is it necessary to move the pump to the back too?
Why not leave the pump in the engine bay but just relocate the tank to the back?? |
05-31-2012, 01:35 PM | #10 |
boom
12
Rep 598
The pump has a hard time pulling fluid that is lower than it, you can leave the pump under the engine bay but you will have to re-prime more often than if it's in the trunk and lower than the tank.
Additionally it's going to be cooler in the trunk most of the time, so if you're doing any kind of road courses this is better for prolonged meth use. |
05-31-2012, 01:35 PM | #11 |
Rep 70
The pumps used in these kits are pusher pumps and not puller. The further away from the tank the more stress will be put on the pump. This can cause air bubbles, priming issues and inconsistency with pressure.
05-31-2012, 01:36 PM | #12 |
Rep 56
Don't know if it should be moved, but I would prefer to do so because the pump is another potential source of leaks and leaking in the engine bay is more likely to start a fire than the trunk (if you keep away from the battery) and the cooler temps will help with the life of the pump?
05-31-2012, 06:49 PM | #13 |
278
Rep 5,062
Drives: Black e92 335i
I have actually put together 2 different kits on paper so far.
1) An underhood mini fuel cell with all 4an stainless lines, copper fittings, etc. It's mounted near the wheel well and the filler neck is basically a long 16-20 AN line which runs up into the engine bay and is then secured against something or basically tied up somewhere to stay in place. You put in a funnel and fill it up and then install a copper fitting to seal the hose after you are done. Throw a low level sensor into the fuel cell prior to mounting it and basically figure out how much methanol to add once the low level sensor goes off so there's no more guessing involved. Just not sure if I wanna go through the trouble of this yet. The tank will be vented to the wheel well. 2) A trunk mount kit using 4an fittings and lines everywhere. The only thing I haven't decided is how to tap a tank for 4an lines. Options are to use the normal quick connect and then an adapter to 4an, or to use a 4an bulkhead fitting, but I haven't used these before so I'll have to do some research on it.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
05-31-2012, 06:53 PM | #14 | ||
3441
Rep 79,211
These pumps cant pull fluid that well. Maybe at 30-50 psi max. So it's best when using a tank to mount it underneath. The most reliable meth system I had was a simple 4 quart tank with the pump mounted below. Never had any air in the lines and always consistent flow. For those not willing to listen you will soon find out |
05-31-2012, 07:11 PM | #15 | |
Rep 56
05-31-2012, 07:13 PM | #16 | |
3441
Rep 79,211
05-31-2012, 08:29 PM | #18 |
23
Rep 647
This guy was able to run all stainless lines using the Aquamist HFS-4 which is similar to the vishnu pwm kit
Here's a link to the aquamist site: http://www.aquamist.co.uk/vbulletin/...t=2158&page=25 His name is 03 Biest, I'm sure you could ask him where he got the SS lines and fittings Last edited by 805beemer; 05-31-2012 at 11:59 PM.. Reason: youtube link |
05-31-2012, 09:17 PM | #19 |
278
Rep 5,062
Some fittings/conversion ideas I had:
For the pump 3/8 NPT to -4AN fittings to allow the stainless lines to connect directly to the pump and for the solenoid I was going to get one from devil's own that is already setup for the stainless lines or use a solenoid that has female connections and not quick connects and then just use an NPT/AN fitting. For the Nozzle you can get an AN nozzle holder.
05-31-2012, 09:54 PM | #21 | |
278
Rep 5,062
Just asked my dad about this since he used to be a car nut, he pulled out an old school compression to AN6 fitting and told me how he used it on his old cars fuel system way back in the day. If I had the PWM system he could tell me everything required to make the necessary adjustments he said and how to source the parts. Maybe someone can post a pic with all the parts that come in the PWM system for me.
06-05-2012, 04:17 PM | #22 | |
46
Rep 1,145
Maybe 1 foot of tubing... |
