The Official Vishnu Procede E85 Tuning Thread
05-30-2012, 12:29 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
The original thread thread was moved to the vendor classified section due to the Rev2.5 Special Edition sale. So this thread will be dedicated to discussing e85 tuning/map setup.
Let's start off with a datalog Big Tom sent me this morning when testing the new 5-23 e85 maps. As required, they were tested using a 50/50 mix of e85 and premium grade gasoline. Big Tom's car is a 6MT with FBO while spraying 800cc/min of ethanol/water mix (80/20). He also gradually start boost to 85% (from default of 35%). And here is his 3rd-4th gear datalog: This is a good example of what you want to see. First, fuel trims aren't maxing out at +35%. In this case, they are only going up to ~20% in the midrange and falling down close to 0% at high RPM. Which is great and indicative of a fuel system that isn't working very hard. The meth injection is certainly helping things out here. So don't expect to be able to run this high boost setting without some form of meth injection. If you do, you will likely see your fuel trims flatlined at +34% for most of the RPM band. Second, timing is reaching the target values. You will see 12-14 deg of actual advance up to 6000rpm. And then ramping down to 11-12 deg above that. That is perfect. And lastly, AFR is nice and equal between bank 1 and bank 2. If your nominal AFR values look strange, make sure you drop the new datalog set-up files into your Procede folder (as explained in the Read Me) file. If you don't, you nominal values will be off. If you guys have any questions or have logs for me to look at, please email them to be directly at shiv@vishnutuning.com. Please do not post datalogs in this thread since these maps are still very much in BETA stage. Shiv |
05-30-2012, 12:44 PM | #3 |
1737
Rep 17,960
Drives: A Lot
05-30-2012, 01:03 PM | #6 |
1737
Rep 17,960
Drives: A Lot
I'd say precise as possible without actually measuring it with a set of kitchen measuring cups. The fuel in the fuel line and tank will mix by the time you leave the gas station. That's not a big concern. I doubt many people will be able to do a full boost launch fight from the pump.
05-30-2012, 01:10 PM | #8 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Just tried these maps out during my lunch break... Absolutely amazing.
05-30-2012, 01:10 PM | #9 |
1737
Rep 17,960
Drives: A Lot
05-30-2012, 01:40 PM | #10 | |||
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
05-30-2012, 01:42 PM | #11 |
Rep 118
05-30-2012, 02:12 PM | #14 |
324
Rep 2,663
05-30-2012, 02:15 PM | #15 |
Some say...
239
Rep 4,296
Drives: Fresh
But what if we do not have access to e85 and we are out of fuel and we need to fill up with just gasoline, do we just switch to a different map that is ok to run with gasoline?
I have exhaust and an intake... |
05-30-2012, 02:17 PM | #16 |
1737
Rep 17,960
Drives: A Lot
For now, just switch over to map0 if you don't have your laptop and upload a gasoline map file.
05-30-2012, 02:21 PM | #17 | |
422
Rep 8,003
Map 0: Stock Map 1: 93 Map 2: 93 + Meth Map 3: N/A Mode (with the adaptation issues fixed) Map 4: E85/93 Map 5: E85/93 + Meth |
05-30-2012, 02:23 PM | #18 |
Some say...
239
Rep 4,296
Drives: Fresh
Yes this would be beautiful haha
05-30-2012, 02:27 PM | #19 |
1737
Rep 17,960
Drives: A Lot
Additional map selections will be offered after this initial beta release. I'm not a big fan of introducing that many new variables at this stage in testing a new fuel.
05-30-2012, 02:45 PM | #20 | |
114
Rep 2,428
The only problem I see is that there is only one AFR Offset table for lamda calculations. Come to think of it, I can't really think of any tunes (even for other platforms) that can simultaneously offer a seperate AFR table for both gasoline and E85. You kinda just have to pick one and go with it. If you're stuck and can't get E85..big whoop, just run map 0 until you're home. It's not like you're stranded because you can't have 440hp on tap. |
05-30-2012, 02:50 PM | #22 | |
1737
Rep 17,960
Drives: A Lot
