Are you wondering how much boost is safe for stock turbos ? Calculations inside !
05-29-2012, 06:18 PM | #1 |
313
Rep 3,262
Hi,
EDIT: I have now added maximum power and maximum torque figures. Now you can see how meth helps ! Have you ever wondered how much boost is really safe for your stock turbos, and how to calculate it ? The sticky thread about the Mitsubishi TD03 turbo characteristics does not mention any calculations, just speculations. This was driving me mad. I needed real answers based on calculations. With the help of a software program that I just made, I have calculated how much boost is safe for the stock N54 turbos, at each RPM. Based on the results below and your logs, you can see if your turbos are inside the efficiency range or you are pushing them too hard. I used these materials as a reference: This tells you how to calculate various parameters: http://www.turbobygarrett.com/turbob...Catalog_V4.pdf This tells you the Mitsubishi TD03 turbo efficiency maps: http://www.e90post.com/forums/showthread.php?t=256804 Algorithm: For each RPM (in steps of 100), check each psi value from 22 down to 0, in steps of 0.1psi, and see if the resulting values (pressure ratio, air flow) is inside the efficiency maps using an algorithm to determine if a point is inside a polygon. Of course, it's a bit more complicated but this is the essence. Here are the results for an IAT of 40 Celsius (104F) and a pressure drop (intercooler + piping) of 1.5psi: RPM PSI HP Nm 1300 4.00 55 302 1400 6.50 67 343 1500 15.80 104 493 1600 17.50 117 521 1700 17.60 125 522 1800 17.70 132 524 1900 17.80 140 525 2000 17.80 148 525 2100 17.90 155 527 2200 18.00 163 529 2300 18.10 171 530 2400 18.20 179 532 2500 18.30 187 534 2600 18.40 195 535 2700 18.50 204 537 2800 18.50 211 537 2900 18.60 219 538 3000 18.80 228 542 3100 18.90 237 543 3200 19.00 245 545 3300 19.10 253 546 3400 19.20 262 548 3500 19.30 270 550 3600 19.40 279 551 3700 19.30 286 550 3800 19.20 293 548 3900 19.10 299 546 4000 19.00 306 545 4100 18.90 313 543 4200 18.70 319 540 4300 18.60 325 538 4400 18.50 332 537 4500 18.40 338 535 4600 18.10 343 530 4700 17.70 346 524 4800 17.30 349 517 4900 16.90 352 511 5000 16.50 354 504 5100 16.20 358 500 5200 15.80 360 493 5300 15.50 363 488 5400 15.10 365 482 5500 14.80 368 477 5600 14.50 371 472 5700 14.10 373 466 5800 13.60 373 458 5900 13.00 371 448 6000 12.40 369 438 6100 11.90 368 430 6200 11.30 366 420 6300 10.80 365 412 6400 10.20 362 403 6500 9.70 360 394 6600 9.10 357 385 6700 8.60 354 377 6800 8.20 354 370 6900 7.70 351 362 7000 7.20 348 354 7100 6.80 347 348 7200 6.40 345 341 7300 6.00 343 335 7400 5.60 341 328 Here are the results for IAT of 22 Celsius (74F) - for example if you are using meth - see how the psi is the same, but the max power increases by 24hp: RPM PSI HP Nm 1300 4.00 59 321 1400 6.50 71 363 1500 15.80 110 523 1600 17.50 124 552 1700 17.60 132 554 1800 17.70 140 555 1900 17.70 148 555 2000 17.80 156 557 2100 17.90 165 559 2200 18.00 173 560 2300 18.10 182 562 2400 18.20 190 564 2500 18.30 199 566 2600 18.40 207 567 2700 18.40 215 567 2800 18.50 224 569 2900 18.60 232 571 3000 18.70 241 572 3100 18.90 251 576 3200 19.00 260 578 3300 19.10 268 579 3400 19.20 277 581 3500 19.30 286 583 3600 19.40 296 584 3700 19.30 303 583 3800 19.20 310 581 3900 19.10 317 579 4000 19.00 324 578 4100 18.90 332 576 4200 18.70 338 572 4300 18.60 345 571 4400 18.50 352 569 4500 18.40 359 567 4600 18.10 363 562 4700 17.70 367 555 4800 17.30 370 548 4900 16.90 373 542 5000 16.50 376 535 5100 16.20 379 530 5200 15.80 382 523 5300 15.50 385 518 5400 15.10 387 511 5500 14.80 391 506 5600 14.50 394 500 5700 14.20 397 495 5800 13.60 395 485 5900 13.00 393 475 6000 12.40 391 464 6100 11.90 391 456 6200 11.30 388 446 6300 10.80 387 437 6400 10.20 384 427 6500 9.70 382 418 6600 9.20 380 410 6700 8.70 377 401 6800 8.20 375 393 6900 7.70 372 384 7000 7.20 369 375 7100 6.80 367 369 7200 6.40 366 362 7300 6.00 364 355 7400 5.60 362 348 Now let's have a tuner push these turbos to the max, it seems to me there is plenty of room in the midrange
05-29-2012, 06:28 PM | #2 |
Rainbow Racer
1008
Rep 2,539
Thanks, Subscribed!
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
05-29-2012, 06:31 PM | #3 |
33
Rep 886
I'm pretty sure those two charts are exactly the same
Performance: JB4 ECU, CP-E DP's, WW BMS Meth Kit, AR meth elbow, BMS DCI, AFE Intake Scoops, Exterior: Enkruez 19" H8R, H&R Spacers, Aero Lip, Tint, ACS Roof Spoiler, HID AE's, HID Fogs, Black Grills, Sport Pedals |
05-29-2012, 06:33 PM | #5 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Both of your datasets are the same.
05-29-2012, 06:39 PM | #6 |
313
Rep 3,262
That's what came out of the program. But they are not identical, example: at 3000RPM, the 40C set has 18.80 max psi while the 22C set has 18.70 psi.
The IAT does not really influence turbo efficiency because the air is cooled only after it passes the turbocharger, so it really shouldn't play a huge role in establishing the maximum turbo PSI for a given RPM, not saying it doesn't play a huge role in other areas of combustion. So the turbo receives ambient air, and gets out hot air. The IAT has nothing to do with this, it plays a role after this, with the ECU reducing the boost because there is plenty of oxygen due to the denser air. So you can make more power with less boost, but this doesn't mean that the turbos can push more psi at a given RPM.
05-29-2012, 07:27 PM | #9 |
12
Rep 232
18.7psi for me
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
05-29-2012, 09:54 PM | #14 |
78
Rep 887
05-30-2012, 07:51 AM | #15 |
313
Rep 3,262
I have now added maximum power and maximum torque figures. Now you can see how meth helps, there is a 24hp gain from 40C to 22C in IAT.
To be honest, I got these exact numbers on a well calibrated Mustang dyno that I am using. It's amazing how the numbers match.
05-30-2012, 08:09 AM | #17 |
313
Rep 3,262
Garrett states that 4-valve heads have a VE of 95%-98% (I used 95%).
05-30-2012, 09:35 AM | #18 |
33
Rep 1,029
VE is at its peak during peak power on variable valve engines, you cant use the same VE for the entire RPM range, you gotta start with peak VE at peak power output and scale it down with lower RPMS.
05-30-2012, 10:15 AM | #19 |
313
Rep 3,262
The question is, do you really need super accurate calculations of power at 4000RPM, or are you looking for the most accurate calculations at the RPMs with the maximum power, like 5000-6000RPM, where VE is at its peak anyway ? Also, between 95-98% is a small enough range to not really matter. Likewise with the AFR.
05-30-2012, 11:43 AM | #21 | |
33
Rep 1,029
05-30-2012, 11:53 AM | #22 |
3441
Rep 79,211
Definitely plenty of room in the mid-range. I remember when Cobb first came out everyone was bugging out about seeing 16-17 PSI in the mid-range, its perfectly acceptable for this car so as long as its not at redline.
I had to dial back the boost on the stage 3 PROcede maps, too much torque for the stock clutch on my car. Car is a beast down low. |
