Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Wastegate Actuator replacement
      05-29-2012, 10:57 AM   #1
scflaw
208
Drives: M135I, Macan S, G26 i4M50
Hey guys
Any of you had any experience with replacing the wastegate actuator on our engine? My car is giving me limp modes when i go into boost, saying that the waste gate was closed/stuck. Any Ideas? Thanks
      05-29-2012, 10:58 AM   #2
BMWsky
24
Drives: 335i
Are you running a tune? If so, which one and what are the conditions?
      05-29-2012, 12:15 PM   #3
Lulz_M3
33
Drives: AW 335i 6MT
Just use a long extension (or similar) to move the wastegate actuator arm to free up the valve. Shouldn't need to be replaced, they just get stuck sometimes.
      05-29-2012, 02:47 PM   #4
JamesM3M5
Some dude
92
Drives: E92 335i
Sometimes the lever arm shaft - the one that goes into the exhaust housing and connects the wastegate valve to the actuator arm - gets very sloppy and binds up. Only fix for that is to replace the turbo.
RRT
E92 335i/6MT with stuff and things
      05-29-2012, 08:26 PM   #5
scflaw
208
I don't believe its isolated with the tune.
I'm running Cobb Sport 4.01, no other engine mods
and it only happens when the engine is at optimal (117-120 C) temperature's.
never happens when the engine is cool, which is weird.
i do notice that when i switched tunes from 3.01 - 4.01, that the problem didn't happen as much. I hope i won't have to replace the turbo, thats gonna be a huge PITA.
      05-29-2012, 09:26 PM   #6
BMWsky
24
Drives: 335i
If you threw code P30FE, a few of us running Cobb have been having this issue. I get it, but only at the track. Supposedly, the new maps will address this but I'm thinking about trying a different tune.
      05-30-2012, 01:11 AM   #7
scflaw
208
Ahhhh okay thats good, I find that the problem is exasperated by octane boosters. Just as an update
      05-30-2012, 05:55 AM   #8
Tari
66
Drives: MG M4
I have a similar problem. Can you guys help me? It is throwing 30ff underboost and going into limp mode. Had a smoke test done and the guy said its my waste gate actuator. Ecs sells new actuators for $32 but the guy wants to charge 7 hrs of labor is that fair ?
      05-30-2012, 06:47 AM   #9
Pyrrhic
Pyrrhic's Avatar
Drives: 2008 335i
My N54 encountered the exact same problem.
Since mine is a CPO, I took it in for repair. At first they replaced some VANOS components and some ledges/bearings. That still didn't do the trick...After they noticed that their was significant play in the wastegate...They chalked that up as the culprit.
End result? Two brand new turbos and oil lines...Car runs like a champ now.
      05-30-2012, 08:00 AM   #10
BMWsky
24
Drives: 335i
Was your car modded in any way or was it overboosting while it was stock?
      05-30-2012, 08:10 AM   #11
Pyrrhic
Pyrrhic's Avatar
Drives: 2008 335i
Just JB4+DCI.
Removed for service in about 15 minutes in the parking lot...Installed a few days after getting it back.
      05-30-2012, 11:12 PM   #12
scflaw
208
Shit that is going to be rape on the wallet, if thats the same problem i'm getting. i was hoping on just replacing the wastegate
      05-30-2012, 11:20 PM   #13
BostonBeemah
BostonBeemah's Avatar
Armenia
72
Drives: AW 135i 6spd
I've actually been having similar issues. I have no codes but my my car has been overboosting lately after going full wot at full temp like you. I just got the wastegate actuator in today and will try to get it installed tomorrow if I have time. I'll report back when I get it in to see if it ended up fixing the problem.
2010 AW/BLK 135i VM 6465 Single Turbo, JB4 + MHD, VRSF CP & Tial, Big Tom, Fuel-It PI + Stage 3 + Return + Ethanol Sensor, BMW PE, MFactory LSD, Spec 3+ & MFactory SMFW, RB External PCV
Best stock turbo 12.5 @ 19.46 spinning all the way down
RIP 2008 AW/BL 135i
      05-31-2012, 02:37 AM   #14
scflaw
208
Thanks Bud, Keep me posted
      05-31-2012, 12:36 PM   #15
DriM3
DriM3's Avatar
Drives: 2008 335i
Interested to see if this will fix the problem we're all experiencing
