Which first
05-29-2012, 09:44 AM | #1 |
25
Rep 437
Which first
Currently running procede v4 rev 2.5, BMS dci, custom weld exhaust. Should I get downpipes or an Intercooler first?
I figure since summer is here on the east coast, I should get an Intercooler. However, I really want to get that awesome sound with the downpipes. If I run my current set up w/out an Intercooler will I run the risk of overheating? I don't track the car, but give some good wots here and there daily. Thanks all. |
05-29-2012, 09:49 AM | #2 |
161
Rep 7,377
Get an intercooler first and downpipes later on or just do both together...
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-29-2012, 10:06 AM | #3 | |
79
Rep 2,396
Drives: '08 E90 335i
Makes the most sense doing both at the same time, that way you (or the mechanic) only has to get under the car, let you save some time/money. |
05-29-2012, 11:31 AM | #5 |
3441
Rep 79,211
The best approach is FMIC, it keeps intake air temps down, improves efficiency, and increases throttle response. It also reduces the chance of heat soak from back to back pulls.
Eitherway you go you will enjoy it. Let me know if you need any help. |
05-29-2012, 11:33 AM | #6 |
194
Rep 6,136
+1
