Advice needed: AA Bov not blowing
05-28-2012, 04:51 AM | #1 |
83
Rep 861
Hey guys,
Over the weekend, I installed my AA bov to my stock 335. Once everything was installed, tried it for the first time, no blow off happened. I could see the valve inside moving when revved but no blow off. So I took it for a drive when warmed up, no blowing off on any gear changes at all, no error mesages on the dash, car driving exactly as before installed. Tried revving to 6k before changing gears and heard a little blow off however hardly noticeable. What could be the issue here? the vacuum line is going to the T from the factory line, where one side is capped off (as I did not want to break the nipple on the intake manifold when installing). Do you think I have a leak somewhere? At idle, the bov doesnt seem to be puffing air, and I can hear a very slight hissing noise from somewhere. this also normal? I can upload a video if that helps identifying the problem.
05-28-2012, 08:54 AM | #3 |
915
Rep 3,456
Drives: Harrop E90 M3
There are 2 nipples on the AA bov typically. Do you have the vacuum line hooked to the top or the bottom? Should be on the top fitting.
05-28-2012, 09:07 AM | #4 |
83
Rep 861
Yes, it is connected to the top one. However if I had a leak, would it not show an engine light on the dash?
05-28-2012, 09:12 AM | #5 | |
115
Rep 288
Did you purchase it with a charge pipe ? Bov have different lb. springs of you got universal one make sure you have the correct spring for your car. I'm not sure what bmw vacume pressure is. My supra used a 10lb. |
05-28-2012, 10:56 AM | #6 | |
83
Rep 861
Do I need to fiddle with the screw on the top of the horn?
05-28-2012, 10:59 AM | #7 |
915
Rep 3,456
It would take a while for the adaptations to get out of spec enough to cause a light. Might have to give them a buzz tomorrow of you can't find it. The caps didn't blow off the factory DV locations did they?
Don't adjust the screw on top! |
05-28-2012, 11:12 AM | #8 | |
83
Rep 861
Isit still safe for me to drive the car, knowing the blow off is not working?
05-28-2012, 12:38 PM | #9 | |
146
Rep 1,201
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
05-28-2012, 04:13 PM | #10 |
148
Rep 965
Drives: e92 m3
mine doesn't blow much on stock boost,try a high gear on low rpm n let the boost build n see if it blow at all.get a tune if u want it to blow the rite way
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
11-14-2013, 09:05 PM | #11 |
16
Rep 566
I have AA BOV and chargepipe combo as well. I have read somewhere that for the top bolt, there should be 6 rings to be seen to be correct. Mine works fine and it also has 6 rings visible. Just FYI.
11-14-2013, 09:31 PM | #12 |
3441
Rep 79,211
I never put a BOV on a stock car but it might not be enough boost to make that much noise.
At any rate a hissing noise doesn't necessarily sound right. Maybe get a video. |
