Cost to add Oil Cooler?
05-26-2012, 08:16 PM | #1 |
52
Rep 210
Does anyone know what I should expect to pay for BMW to add an oil cooler to my 335xi?
Since its a CPO, I'd sort of like BMW to install it for me... Thanks, |
05-27-2012, 10:16 AM | #2 |
Rep 76
800-1200 were the quotes I received.
I wouldn't even bother however...Every now and again I rip hard in my n54...and I mean hard. I've never had temps creep above 250. So unless you plan on tracking your car often in high heat...allocate those funds elsewhere. |
05-27-2012, 11:37 AM | #5 |
Rep 109
Ask a local custom ecu tuner sometimes they can control when your fan comes on in a custom flash, if you want to go that route. I had that done with my Evo.
05-27-2012, 06:48 PM | #6 |
BMWCCA 149159
38
Rep 847
I had this done right after I learned BMW didn't install the 2nd cooler. It cost me 900 bucks for them to install and the only reason I did that was because I wanted no issues regarding warranty. BMW cooler parts and BMW techs installing it.
So this is a real not imaged data point for the install. By the way I almost never see my temps over 250. In Germany when I ran it hard but respected the 4500 rpm limit it hit 270 and that was at 50 F so it helps a lot. I plan to go from JB plus to Cobb Stage 1 and want the cooler to help keep the temps in check...; |
05-28-2012, 12:12 PM | #8 |
Rep 114
Hey man I'm in Denver, in the same boat. So, around $900 just for the labor? That would be reasonable through the dealer.
I would be interested to hear about your experience, thanks, Peter B.
BMW Perf Suspension, Lowering Perches, Cobb AP Stg 2+, cp-e DPs, ER Performance IC, Forge DVs, Stett CP, AR Oil Cooler, Beyern Mesh 18" 275/235, Golf Tee, Tint 20%, Vinyl Wrap Int Trim, MTEC V3 AEs, BMS DCI and DP Fix, M-Tech Front/Rear [B][I]
05-30-2012, 01:30 PM | #11 |
79
Rep 2,396
Drives: '08 E90 335i
Why do you want to pay stealership cost for something that doesn't even work that great? For the same cost, you can buy something more effective. Get the ER Sport Series Oil Cooler ($795) with the retrofit ($425)
http://www.evolutionracewerks.com/node/132 |
05-30-2012, 02:09 PM | #12 |
69
Rep 2,934
holly heck
I have done a few track days and pushed pretty hard and with JB4 and 'max cool' mode never seen the oil temp go over 1/2 way and 5 minutes back in the sheds drops to 1/3 |
05-30-2012, 02:11 PM | #13 |
116
Rep 1,346
Drives: 2011 E92 335 M-Sport
and you got these results with or without the factory oil cooler?
05-30-2012, 02:19 PM | #14 | |
69
Rep 2,934
i have the small stock oil cooler in the passenger (for you lefties) wheel well. its pretty small and was stock for us folk down under. I have been looking at the upgraded oil coolers for a while but to date i have seen no need to upgrade. I have the dct box if that makes a difference and the only time i have seen a limp (gearbox not engine) is in heavy traffic whilst giving the car a squirt. |
05-30-2012, 02:24 PM | #15 |
79
Rep 2,396
As far as i kno, ER is really the only reputable company that offers both oil-cooler upgrade kits. They come in two versions, the Sport kit (basically replaces the OEM oil cooling hardware, could be used to retrofit if your car didn't come w/ an oil cooler) and a race kit (basically its 2 Sports kits, putting the cooling ducts in both the front right & left wheel wells).
05-30-2012, 03:09 PM | #16 | |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
05-30-2012, 03:13 PM | #17 |
116
Rep 1,346
@roundel335
@benzy89 What does labor of this ER Cooler look like cost wise?
05-30-2012, 03:18 PM | #18 | |
79
Rep 2,396
If you're retrofitting it'll take a little longer than an upgrade since they'll be starting from scratch + will have to cut up your wheel well for proper ventillation. Go to your regional forum & get some local Indy's to give you an estimate -- You're in CA so you've got plenty of install shops to pick from that would have experience w/ this kinda work. |
05-30-2012, 03:30 PM | #19 |
Rep 150
Why isn't there a kit that leaves the stock cooler alone and adds another oil cooler on the opposite side?
Why buy the sport cooler from ER to just replace one that is already there? Seems like a lot of work to go from having one cooler to having still just one cooler.
2008 335i Coupe TiAg - Cold Weather - Premium - Sport - Style 230 19's - SatNav - Active Steering/Cruise - Comfort Access - PDC
05-30-2012, 04:28 PM | #20 |
114
Rep 2,428
I made this for rougly $650. I previously had the AR Design oil cooler (for sale if you're interested) but that didn't do much for tracking.
This is the only solution I've found to actually do something for track driving. -Bought oil coolers and lines directly from Setrab (625 series) -Bought oil cooler housing adapter from Turner Motorsports -Got Border Collie from bcrmn.org oil cooler 2 by MDM Enterprises, on Flickr (Don't worry about the extra long bolt that sticks down from the bracket- that is one of the splitter supports. ) oil coolers 3 by MDM Enterprises, on Flickr oil coolers 4 by MDM Enterprises, on Flickr |
05-30-2012, 04:52 PM | #21 |
164
Rep 2,556
Does the louvered debris shield sit flush w/the fender liner? Is it plastic or aluminum?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
05-30-2012, 05:47 PM | #22 | ||
79
Rep 2,396
I'm assuming why they don't offer a kit to compliment the OEM one because it prob needs special hoses/connection terminals for two oil coolers being run to the OEM oil filter. Quote:
Here's a picture directly of ER's website of their enclosure. |
