How your timing should look
05-26-2012, 04:21 PM | #2 |
208
Rep 2,558
Why does ignition advance so much during the first ~1.3 seconds of the datalog prior to you depressing the accellerator?
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-26-2012, 04:25 PM | #3 |
313
Rep 3,262
Mine look like that even on high boost...
05-26-2012, 04:33 PM | #4 |
17
Rep 205
05-26-2012, 04:35 PM | #5 |
17
Rep 205
05-26-2012, 04:57 PM | #6 |
70
Rep 2,197
Because there is no boost. When there is no boost the DME will advance timing as if the car was NA. When the DME transitions into spool mode the DME then pulls the timing
05-26-2012, 05:24 PM | #7 |
313
Rep 3,262
Here's one without meth...note that the boost is identically high at 16psi max...
05-27-2012, 12:19 PM | #9 | |
17
Rep 205
For what it's worth, on AZ 91oct fuel w/o meth and the high IAT's, I really can't seem to run much more than 11-12psi without seeing timing drop. :-( |
05-27-2012, 12:51 PM | #11 | |
161
Rep 7,377
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-27-2012, 12:52 PM | #12 | |
70
Rep 2,197
05-27-2012, 01:24 PM | #13 |
65
Rep 1,708
OP you should be able to run 14psi+. Your iats are too high for meth... You're fbo + vishnu pwm right? I usually see <80degF, even when 100deg ambient... Our dry air will show much greater temp swings then other areas.
I target about 8 deg advance in the mid-range ramped to about 11deg at 6000rpm with boost at 14.5ish midrange. Somethings not right in your setup with 35+ C iats. Ill check my logs again soon to confirm. |
05-27-2012, 02:49 PM | #14 | |
17
Rep 205
05-27-2012, 03:00 PM | #15 | |
313
Rep 3,262
Yes, GIAC Stage 2 Race.
