Reoccurring combination of warning lights
05-26-2012, 03:18 AM | #1 |
Rep 9
The following combination of warning lights keeps simultaneously appearing approximately once a week. All are yellow and not flashing. The lights will stay illuminated for the entire trip. After the car is turned off and left off for a while, the warning lights all go away. Looking in the manual, the only combinations I've found were to be the Drive off assistant and suspension control system failures. The Drive off assistant is indeed not working (only while the warning lights are illuminated) and I don't know how to test the suspension control system.
Anybody else have had this particular combination happen? Any ideas what could be causing it or what should be fixed? Any help would be appreciated |
05-26-2012, 06:15 PM | #3 |
Rep 9
Tire pressure is good, but they do tend to lose air once in a while. Brake sensor wiring are connected but the sensor is ziptied up behind the wheel well covers. Car is an '06.
Could any of these be the culprit? |
05-26-2012, 06:18 PM | #4 |
346
Rep 2,396
Looks like a loose ground somewhere ABS unit.
I had a loose ground connector in the trunk, was getting random errors about trunk being open, license lights being out, TPMS, etc. |
