Which engine oil?
05-24-2012, 10:46 PM | #2 |
171
Rep 1,178
Really? 5w30. Open hood. Look at oil fil cap...it'll tell you Castrol recommended. It should also say full synthetic somewhere under the hood. Or maybe even in the owners manual
05-25-2012, 12:58 AM | #3 |
38
Rep 225
Mobil1 0w40
He asked a question and was just looking for an answer, not to be preached. Last edited by BoricuaE92; 05-25-2012 at 07:23 AM.. Reason: Correction |
05-25-2012, 05:50 AM | #4 |
Rep 150
Adding oil or changing oil? Honestly... it's a pretty heated debate if you're talking about chainging it.
Castrol Edge Euro Formula 0w-30 and Mobil 1 0w-40 full synth are the two front-runners and on average, you'll find the perform very similarly to each other (if doing a full change) If you're just adding oil (topping off), the only important factor to consider is that the oil MUST BE LL-01 approved. This can be difficult to find in gas stations, however... I know that it probably seems trivial and probably is in a lot of scenarios, however, you have a 335 which runs the oil quite a bit hotter than other engines (uses it as a coolant for the turbos), and for my $$, I'd stick with what they recommend. |
05-25-2012, 05:56 AM | #5 |
17377
Rep 18,772
First off, this post is in the wrong section. Second, Forum rules suggest doing a search on topics before actually asking a question. So, maybe a look at the Mechanical Maintenance... (Oil & Fluids) section and seeing the 1st sticky "Oil Change - what oil to use" might have answered the OP's question...
05-25-2012, 06:14 AM | #6 | |
14
Rep 396
2014 F30 M-Sport 328i, Estoril Blue, Sport Auto, Moonroof, Lighting Package, Navigation, Harman Kardon, Black Performance Grilles, Stainless Pedals.
05-25-2012, 07:22 AM | #8 | |
38
Rep 225
05-25-2012, 07:45 AM | #9 |
ಠ_ಠ
18
Rep 816
05-25-2012, 09:30 AM | #13 | |
535
Rep 1,873
That's the wrong Syntec. It's not thick enough (the 0W30 Euro formula is thicker, consult the PDS) and neither ACEA A3 or LL-01 rated. For just about the same price, get the 0W30 next time.
Use an LL-01 (or in a pinch, just ACEA A3) rated 30 or 40 weight. |
05-25-2012, 09:46 AM | #14 | |
dual Afe intake/ cobb/ forge dv's/ 94 oct.
11
Rep 309
05-25-2012, 10:20 AM | #15 |
535
Rep 1,873
05-25-2012, 04:37 PM | #19 | |
535
Rep 1,873
They also spec 20,000km+ oil change intervals and "lifetime" driveline fluids. I don't believe everything BMW says without question. |
