No need for Xede or TT...read on
06-29-2007, 12:31 AM | #1 |
Rep 8
I spoke to a reputable tuning house (will send you their details in PM if requested), and they reckon the 335i ECU can be programmed permanently to get the same gains you see with Xede etc.
Anyone heard about this before? |
06-29-2007, 12:39 AM | #3 |
26
Rep 865
Drives: 2018 F15 X5 xDrive35d
Maybe...Until you take the car for the service and they reflash your ECU with a new version of software or something and bring it back to stock.
06-29-2007, 01:10 AM | #5 |
335
Rep 7,719
Yes, this sounds like a normal flash that you can get n a car like the Evo/STi...a popular one is DynoFlash.
It is cheaper than a piggyback at FIRST, but it is not upgradeable. So when you get new mods, you will need to pay for a retune again...which can be costly over time. And it will be detectable at the dealerships. |
06-29-2007, 09:49 AM | #6 | |
Rep 304
06-29-2007, 11:21 AM | #9 |
335
Rep 7,719
What handheld units? A reflash is not a piggyback or anything like that...you connect a laptop with the supporting program, ie ECU FLASH, into the car, and write over the stock map. My friend does this for a living on the Evos. Works great if you don't plan on modding any further. You can upload your stock map and email it to yourself..but without the data cable and program..you will need to pay someone else to put it back on your car.
06-29-2007, 12:33 PM | #10 |
Moderator
270
Rep 4,481
I'm pretty sure in case we will see a more performant OEM ECU software, it will be still lower than the Alpina numbers. Probably around 340HP, 450NM (crank), like the current Hartge ECU flash.
06-29-2007, 01:29 PM | #11 |
Rep 45
Yeah, lots of tuning companies offer this. http://hondata offers a reflash, as well as a standalone unit (K-pro). They both have their place depending upon your needs.
06-29-2007, 01:38 PM | #13 | |
Rep 304
http://www.americanmuscle.com/diablo...-mustangs.html |
06-29-2007, 02:57 PM | #14 | |
1469
Rep 3,552
Similar thing over in the volvo tuning world, the ECU flashes could be detected by VCNA even after returning to stock as there's no way to clear the flash counter log. I would prefer a piggy back whose only trace is an ecu power loss in the logs.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
06-29-2007, 03:33 PM | #15 | |
Rep 304
06-29-2007, 06:18 PM | #16 |
1577
Rep 3,888
06-29-2007, 06:25 PM | #17 |
Samtaro!
124
Rep 2,601
How much does a new ECU cost? Can one buy a "tuned" ECU, use the "tuned" ecu most of the time, and just swap them before going to the dealer?
06-29-2007, 06:33 PM | #18 |
I'm just here for the turbo
Rep 327
I had the Cobb Tuning AccessPort for my STi. It's a setup as described above. Plug into the OBD port, reflash, done. Quick, easy, simple. Much easier and cleaner than piggyback systems. Had a buddy of mine who was a Subaru tech check it out, and he said that none of their tools could detect the reflashed ECU (or that I was blocking some codes).
Whether you have procede, xede, or any other piggyback or reflash system, you will have to do SOMETHING to account for other mods (i.e. changes to the turbos, fuel system, intercooler, etc, etc). With the AccessPort, just go to a tuner, he'll tune it, and put the new map on your handheld AccessPort device. The device holds all your maps - the "basic" upgrade maps (like with procede - it's an initial map that boosts hp by ~50 and tq by ~80), stock map, any of your new tune maps, a couple valet modes, even a mode that makes it so that the car can't be started.
Current Rides: 2007 BMW 335i Sedan 6MT Montego Blue, 2004 Subaru Impreza WRX STi (for sale), 2004 Mazda RX-8 6MT
Fondly Remember: 1988 Porsche 924S, 1992 Mitsu 3000GT SL, 2001 BMW Z3 2.5i |
06-29-2007, 09:50 PM | #19 |
38
Rep 762
06-30-2007, 02:00 AM | #20 | |
Rep 95
06-30-2007, 06:32 AM | #21 |
Moderator
270
Rep 4,481
06-30-2007, 11:36 PM | #22 |
25
Rep 752
OBD flash loading like that used in other vehicles will not work on this car. The DME must be removed from the vehicle and then opened up in order to program it.
Much easier and safer to order a TT or any of the other piggy backs out there now. Jeff Eurobahn |
