PROcede rev 2.5 datalogging! Check out these logs? Everything stock
05-23-2012, 05:42 PM | #1 |
170
Rep 803
EDITED GRAPHS
Hey guys, Complete beginner to this stuff and I'm currently trying to see if my car is running ok on the 4-23 maps I'm not even sure if I'm posting the right thing, so excuse me if I did something wrong and feel free to point me in the right direction. For reference my car is auto and completely stock besides the tune. I did a lot of runs, some WOT on 2nd and 3rd gear whereas others were not. I cruised on some. Also I noticed my boost lingered at -.5 to .5 Not sure if that's normal? How does it look? Any advice appreciated!
black/black/black e92 loaded
Instagram: _eamon_ Last edited by eamon; 05-23-2012 at 07:01 PM.. |
05-23-2012, 05:45 PM | #2 |
3441
Rep 79,211
Need to see separately
BOOST RPM Can actual ignition Intake Air Temp Can Air Fuel Bank 1 and 2 In a safe place, 3rd gear, start at around 2000 RPM, traction control fully off, wide open throttle till redline. |
05-23-2012, 07:03 PM | #3 | |
170
Rep 803
Just realized I may have not turned off traction fully if that makes a difference, but then again it never cut in during my run either. Also my inlet temp, AFR Bank 1 and Bank 2 would not show as a picture graph, but instead as just a value at any given point of the graph.
Instagram: _eamon_ |
05-23-2012, 09:45 PM | #6 |
208
Rep 2,558
I never understood how to read timing... to me it looks like he's got a huge timing drop, but I'm sure I'm reading it incorrectly... can someone clarify how to read timing for me? Thanks...
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-23-2012, 09:48 PM | #7 | ||
170
Rep 803
Stage one map 1 Aggressive 4-23 Will probably switch back to autotuning 7-29 soon
05-23-2012, 10:31 PM | #8 |
424
Rep 1,325
Your reading it wrong. The 17psi boost pressure is a spike that occurs while shifting, that is normal. What you should be observing is the PSI that occurs during your WOT, which is ~14psi. That is normal.
05-23-2012, 10:33 PM | #9 |
424
Rep 1,325
The huge drop is when he first goes WOT. That is normal. Focus on the timing during the pull, when the rpms start their incline and full boost is met. There is no drop there.
05-23-2012, 10:41 PM | #10 | |
170
Rep 803
Would you personally run this or do you recommend a more conservative map? We are about to go through some serious TX heat this summer if that changes anything haha.
05-24-2012, 04:58 PM | #12 |
424
Rep 1,325
Heat will def be killer. Do some logs periodically and keep an eye out. Thats really the only way to know.
