Help! 4lbs boost but no codes
05-23-2012, 05:05 PM | #1 |
Rep 9
Hey all, at dealer today for warranty work and they performed a boost test, came up at 4lbs (they said stock reading should be 8). NO codes or faults came up. They did a vacuum test and all was good, no leaks. ANY THOUGHTS?
Its a 2008 335XI. The car has a Dinan stage 2 intercooler, active BOV, dual cone intake. The heartbreaker.... dme had to be re-flashed, car had Dinan stage 2 software that dealer refused to re-load b/c I didn't have receipt for install (I am second owner, previous guy never gave me receipt; I was too stupid to ask). Now its on factory settings... even worse with 4lbs of boost. P.S. I am a noob to all this, sorry if I miss any obvious points. Just looking for guidance. |
05-23-2012, 06:24 PM | #2 |
40
Rep 462
It sounds like they didn't erase the dinan properly tell them to fix it erases the dme completely and reflash or find a dinan dealer they might be able to help you
Irub |
05-23-2012, 08:48 PM | #4 |
24
Rep 857
Drives: 2008 Montego Blue 335i
I think that is the case. Find a dinan dealer/shop. will cost you for a reflash though. Should just be their shop time for like 30 mins or so.
05-23-2012, 09:11 PM | #5 |
Rep 9
Thanks for the thoughts. Problem with reflash is that Dinan has no record of my VIN. Kinda think the Previous owner was not so detail oriented and didn't go through a Dinan authorized dealer nor did he keep receipts. Makes a big Problem for me now though. Car is sluggish as hell without software. I will start with telling the dealer to erase complete.... Then what!? Shouldn't boost be more than 4 lbs, even stock.
05-23-2012, 09:19 PM | #6 | |
149
Rep 3,552
05-23-2012, 11:04 PM | #8 |
130
Rep 2,291
If your Dinan is gone, grab a Cobb, JB4 or Procede. You'll have to do your research on which one of the products you want. You'll be gaining hp over the Dinan stage 2 and you'll have the ability to load your own maps.
05-23-2012, 11:47 PM | #9 |
COBB'ed
65
Rep 2,228
Go with COBB. You can use Stage 1+ with your mods.
13 Mini Cooper S 08 E92 335i (SOLD) |
05-24-2012, 12:51 AM | #10 | |
149
Rep 3,552
giac and renntech are flashes like dinan. Cobb is also a flash via small controller called an accessport. procede and JB4 are piggybacks. both are packed with features and great options also. imo procede is the way to go if you have the money. if not then JB4 or cobb. JB4 would be the cheaper of the two. what ever you pick, itll be alot better than dinan. |
05-24-2012, 05:03 AM | #11 |
Rep 9
Once again, being new to this, I am amazed and appreciative of the response and support... Thank you all who have made suggestions. I will definitely look into those tunes.
From the research I have done in the forum, it seems waste gate may be a place to start, as I understand this may reduce boost pressure without storing codes...? Or has to be totally computer related b/c system has been smoke tested and all leaks addressed..... Am I correct? |
05-24-2012, 10:42 AM | #12 | |
nsomneeak
39
Rep 501
05-24-2012, 11:42 AM | #13 | |
30
Rep 283
Feel free to PM me if you would like to discuss your application in more detail. |
05-24-2012, 11:45 AM | #14 | |
30
Rep 283
A data log of your car would give you a very accurate representation of what is going on. I'm not sure where you are located, but I can see if there is a shop nearby that has a Bavarian Technic. This would allow you to read your boost requests and actual, as well as your wastegate duty cycle. Then we could see if it is something related to a leak, or if it is actually electronics related. |
05-24-2012, 11:53 AM | #15 |
Rep 419
I would first get your car back to full operating power.
Then I would look into a new tune. Flash tunes are fine but I would get a handheld one like Cobb so your are not inconvenienced in the future. Otherwise Vishnu Procede or Burger Tuning Jb4 are popular choices. They all make similar power too, so its really a matter of preference. Talk to Jeff@topgearsolutions he is a vendor on here and has all the popular tunes at great prices. |
05-24-2012, 11:58 AM | #16 |
32
Rep 357
It looks like the dealer didn't do a boost leak test. Vacuum and boost leaks are different. If you have loose fitting IC piping, you are most likely leaking boost pressure when the pipes become pressurized with the forced air. A vacuum leak test wouldn't catch this.
There are numerous DIY boost leak tests out there. I'd say start there before blaming the electronics. |
05-24-2012, 12:06 PM | #17 | ||
3441
Rep 79,211
A true boost leak test pressurizes the system to atleast 15-20 PSI. A smoke test or vaccum test doesn't do anything on a boosted platform unless its pressurized. I would look at connections the front mount intercooler, charge pipe, throttle body, and any vacuum lines associated, first. But, if the car is not throwing codes I would imagine it is not getting a good reading at the TMAP, so I would look into cleaning that before I do anything. If you go WOT and underboost for 3-4 seconds you should throw a code. If the car is under warranty I would just go back to the dealer and say something aint right. |
05-24-2012, 12:10 PM | #18 |
Rep 9
Thanks for the suggestions. I will definitely look into the boost test; but what is a smoke test? Is it a vacuum related test? Because they said they did a smoke test, I am just unfamiliar with what they are testing with a smoke test.
@Thomas -- I am located in the Westchester county, new york / fairfield county, connecticut region. There is a popular shop around here called Auto Technic in New MIlford, CT.... any chance they would have the equipment you speak of to diagnose this? What website would have the tunes for reasonable prices? ...just in case I strike out with Dinan. |
05-24-2012, 12:16 PM | #19 |
Rep 9
@Jeff -- Thanks for the input. It does have warranty left, and I am currently scheduling an appt with the dealer insisting that "something aint right"! I am hoping they are not going to play the game with me that it has a BOV and dual cone intake... that is not a BMW approved product, therefore I am S.O.L.! When I get home I will attempt WOT for as long as I can to try and force a code... hopefully giving the dealer something to chew on.
How do I clean a TMAP? (sorry.... noob!) |
05-24-2012, 12:24 PM | #20 | |
3441
Rep 79,211
If you need a stock intake and stock charge pipe with stock diverter valves I have brand new ones I can sell you. Shoot me an email if your interested Sales@topgearsolutions.com You can also visit my site for all other products if any interest you including tunes. |
05-24-2012, 12:52 PM | #21 | |
30
Rep 283
05-25-2012, 06:54 AM | #22 |
Rep 9
All, thanks much for the worthwhile input. The plan is just this... Have an appt at dealer next week for warranty work. Low boost is the priority to fix. Seems like I am outta luck on a tune so will be looking into 1 after my appt. Goal is to get this thing running at the factory 8-9psi of boost, then start from square 1 with a tune.
Given that I am broke, the JB system looks most economical. Is there a huge performance diff between the JB+ stage 2 and JB4 stage 3? Can I run a JB4 stage 3 without an exhaust mod? Kinda liking the $ of a JB+ stage 2, but not sure if I will regret not spending the extra 200 clams. |
