BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Urgent Advice, think I killed my engine
      05-17-2012, 02:13 PM   #1
G-Bus
G-Bus's Avatar
54
Drives: F10
So here's how it goes. I replaced my power steering pump and since the car was jacked decided to change my oil so I got some 5W40 oil and changed that. When I filled the car back up, I only put 5 Quarts (the big jug) and started the engine to see how much more I needed to add.
So engine runs nice and smooth, tells me oil level is OK so I decide to lower the car down, but I left it running since I wanted the power steering system to fill up with oil as well. The engine ran for 5-10 minutes and it started misfiring and I started hearing a really weird noise, like a screw was moving around in a can. Like something was loose and I got a check engine. Checked the check engine and told me Cyl 6 Misfire... Decided to add another quart of oil, figured maybe it was missing oil but nothing changed.
I brought it to a indy garage but I'm so scared right now, I really have no clue what it could be, has anyone else had something similar happen to them?
Any experts have a clue of what mightve happened?
      05-17-2012, 02:15 PM   #2
AU335i
AU335i's Avatar
78
Drives: 2008 335i E92
wow.... always lower the car before you check the oil level... and I've always used 6 1/2 - 7 qts... 2 quarts short sounds like alot... good luck OP.
      05-17-2012, 02:17 PM   #3
zerep1
zerep1's Avatar
40
Drives: 335i E90, 328i F30, 230i G42,
you couldve starved your engine of oil but five quarts is alot i mean its 2 quarts below minimum but should not cause any problems with the car just idling
Irub
      05-17-2012, 02:20 PM   #4
GoRomeo
GoRomeo's Avatar
964
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
I agree. it should not affect the engine to that level. Did you drop something inside the engine block maybe?
Keep us posted
      05-17-2012, 02:21 PM   #5
benzy89
79
Drives: '08 E90 335i
2008 BMW 335i  [7.50]
No smoke/engine didn't freeze you're in "good" shape..... You have any issues w/ misfires before you changed the oil??? Possible you just need new spark plugs/ignition coils on cylinder 6
      05-17-2012, 02:23 PM   #6
Timmayy
Drives: 09 E92 335i Blk/Blk xDrive 6MT
2 quarts low is not good but there's no way it should cause major engine damage.
I've run lesser cars for many miles with the oil level at 50%. I'm sure it shortened the engine's life a bit but it didn't cause catastrophic damage.
      05-17-2012, 02:23 PM   #7
jcarv20s
19
Drives: 2014 435i
The shortage of oil would have thrown an oil light/code instead of a check engine light, no? My guess is you forgot to tighten something...
      05-17-2012, 02:25 PM   #8
G-Bus
G-Bus's Avatar
54
Drives: F10
I had some misfires, like last summer and replaced my plugs back then. I dunno if it's the coil or the plug itself. But that sound is just weird... I really don't understand what it could be.
And I do agree that looking back on it, it sounds dumb but I figured the N54 takes 6.5 Quarts so I was down 1.5, and with 1 out its still very safe to drive. I din't even drive tough, the car just sat on idle.
      05-17-2012, 02:29 PM   #9
zerep1
zerep1's Avatar
40
yeah if it constant misfire it might be the coil-pack or injector sparkplugs have to be in really bad shape to misfire at idle you might also wanna check if some oil might have gotten into spark plug 6 shorting it out cause i imagine the car was at an angle
Irub
      05-17-2012, 02:29 PM   #10
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
Probably has nothing to do with oil but you should start with atleast 6.5 next time. Its unlikely 1.5 low killed the engine at idle.
      05-17-2012, 02:31 PM   #11
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
3129
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Should be no issue with being down a few quarts at idle....name of the game is to keep the oil intake screen covered so the pressure stays up. Not that many places for oil to hide in a 6cyl when a lot of much bigger V8’s are running on only 5 quarts.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      05-17-2012, 02:31 PM   #12
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Could just be a really odd coincidence that something in your fuel delivery system crapped out.
But if you're hearing noises that's not good. Try and find out where it's coming from. If its coming directly from the engine not good.
E90 LCI N54 6AT
      05-17-2012, 02:32 PM   #13
G-Bus
G-Bus's Avatar
54
Drives: F10
Its the noise that worries me the most... It doesn't come from the front of the engine, tough maybe timing chain or anything.
      05-17-2012, 02:34 PM   #14
zerep1
zerep1's Avatar
40
What he is hearing is cylc 6 shut down I does sound like metal slapping when it's completely off
Irub
      05-17-2012, 02:35 PM   #15
Timmayy
Those DI injectors are really loud. Makes it tough to hear any other noises over their clatter.
      05-17-2012, 02:35 PM   #16
G-Bus
G-Bus's Avatar
54
Drives: F10
Ohh that I didn't know? It's normal for it to sound like that when its not firing?
      05-17-2012, 03:13 PM   #17
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
At idle? The car sounds like it has cams after a misfire event but I don't recall ever hearing anything metallic.
E90 LCI N54 6AT
      05-17-2012, 03:33 PM   #18
G-Bus
G-Bus's Avatar
54
Drives: F10
Its not necessarely metallic but it does make a noise I never herd.
      05-17-2012, 05:38 PM   #19
G-Bus
G-Bus's Avatar
54
Drives: F10
I feel really stupid right now...
The garage just called me, verdict is that when I removed the charge pipe I broke one of the clips that hold the DVs. The little plastic peice fell and got sucked into the intake and then in cyl number 6. Lucky me it was plastic so it did no damaged. They looked inside the cylinder and saw the peice took it out, cleared the codes and car runs like a champ.
For now they ghetto rigged my DV with sylicone into place so anyone has a stock charge pipe with good clips for sale?!
      05-17-2012, 05:40 PM   #20
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
I think it's a sign for a cp/bov upgrade
The i8 needs a V8 amirite?
