Removing the rear turbo manifold and downpipe question
06-27-2007, 12:50 PM | #1 |
Moderator
270
Rep 4,481
Anybody has an idea how time consuming this will be ? I got the parts now to install a k-type thermocouple in the rear turbo manifold ( between cylinder #5 and #6 ) to measure EGT and a wideband O2 sensor in the downpipe ( pre-cat ). The data will be logged with the Innovate Motorsports DL-32 device.
Appreciate your feedback. Thanks, Eugen. |
06-27-2007, 01:01 PM | #3 | |
Moderator
270
Rep 4,481
Are exhaust shop's capable to do this on a 335i ? |
06-27-2007, 01:07 PM | #4 | |
96
Rep 2,587
I do have to ask, if you can't change anything, why scan? What will you be looking for? Why not scan the IAT in the ODBII system? |
06-27-2007, 01:11 PM | #5 | |
Moderator
270
Rep 4,481
I like and need to know data: Stock Procede v1 Procede v2 Intercooler Water / methanol injection accurate, single and combined. Last edited by e.n335; 06-27-2007 at 01:41 PM.. |
06-27-2007, 01:26 PM | #6 |
Moderator
270
Rep 4,481
So you think to remove everything, drill the holes, weld on the bungs and put everything back again using new gaskets should be doable within ~ 6 hours ? Would be ok. Sorry for the question again, who should do the job: Any shop ( something like your great custom exhaust shops does not exist in Switzerland ) or better the dealership ?
06-27-2007, 07:26 PM | #7 |
Perf BMW mag issue 147, 159
414
Rep 6,803
I think 6 hours sounds pretty reasonable.... I got the rear turbo on the 535 out in 2-3 hours..
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
06-27-2007, 09:16 PM | #8 |
168
Rep 2,114
in the last week I have pulled off and put back on Downpipes about 20 times..... it takes me less than an hour to pull them off and another 20 mins to put back on if that.
as for the manifold... im not sure.. |
06-27-2007, 09:47 PM | #9 |
296
Rep 1,515
Drives: Ever changing fleet
Why? They do looks fairly easy with all the nice v-band clamping.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
06-28-2007, 03:47 PM | #12 |
414
Rep 6,803
Theres not a way to tape into the DME to get the afr readings? the stock o2 sensor already is a wideband sensor.
06-28-2007, 03:53 PM | #13 |
Moderator
270
Rep 4,481
Not sure. Anyway, the challenge seems to be the EGT sensor install, it would not be too difficult to install the wideband. In addition the wideband is supported from the data logger ( Innovate Motorsports DL-32 & LC-1 ), so the readings will be accurate.
06-28-2007, 03:56 PM | #14 |
96
Rep 2,587
06-29-2007, 05:59 AM | #15 |
Moderator
270
Rep 4,481
Update: Found a BMW dealership in Austria ( I'm there on a regular basis ), willing to do the installation for ~ $600. This is fine with me. When they will have time to do it in about 2-3 weeks. I'll give you an update what EGT temp's / AFR ratios I read with and without PROcede.
FYI. Cheers Eugen Last edited by e.n335; 06-29-2007 at 07:29 AM.. |
06-29-2007, 07:55 AM | #16 |
Rep 49
What is the point of wasting money on doing this?
I really don't understand what type of car you think a 335i with PROcede is. These are chipped, stock turbo 6-cylinder 330whp cars, not 800 whp big turbo radical cars. I'm sure Shiv checked everything out when he put together his PROcede tune, and, once you see the EGT gauge one time, its gonna give you the same reading (within certain constraints) everytime you look at the gauge. Wait, hold on. Is this the fastest car you have ever had? |
06-29-2007, 08:02 AM | #17 | |
Moderator
270
Rep 4,481
