BFWD - attracting WAY WAY too much dust/dirt
05-16-2012, 02:21 PM | #1 |
278
Rep 5,062
Drives: Black e92 335i
So my dad said ever since I put sealant on his car it's always dirtier and that the beaded rain droplets always leave dirt marks all over his car.
So I decided to strip my hood and then put squares of BFWD and holllllyyyy cooooooooooooow. The areas without BFWD still look black and freshly washed, whereas the boxes of BFWD have a LAAAYER of visible dirt. It's not even something only an OCD person would notice, you can literally see dirty squares on the hood just walking past it casually. I guess since I always had my car garage parked I never noticed it as much. I'm going to wash the car and see if the results are the same, I'm thinking maybe it happens only with a fresh coat and after the effects might lessen after a week or two.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
05-16-2012, 03:53 PM | #2 | |
TOML Rescue
Rep 664
05-16-2012, 04:13 PM | #3 | |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I've never had an issue with BFWD. Here's my BSM E90 with BFWD on top of swirls: http://www.e90post.com/forums/showthread.php?t=661895 |
05-16-2012, 06:03 PM | #4 | ||
278
Rep 5,062
I taped off squares and applied BFWD to test my dads theory. Quote:
I wish I had a good cam to capture the results. I showed it to another forum member and even he was surprised. The non-BFWD/stripped areas look normal, whereas the boxes in which I applied BFWD are noticably dirtier and have like a dusty/dirt layer.
05-16-2012, 10:55 PM | #7 | |
278
Rep 5,062
I will do some test spots with FK-425 as well to see if it helps.
05-17-2012, 11:49 AM | #8 | |
76
Rep 1,292
If I have the time the day after a sealant application I will spray the car off with clear water and wipe it down with some quick detailer to get rid of this static. |
05-19-2012, 01:06 AM | #9 |
Rep 31
With a product that hazes and dries using a microfiber to remove it I found there to be so much more static to the surface. Some people like to follow up with a quick detailer and a cotton baby diaper- they are extremely soft! But again, I wouldn't be able to state that it makes a difference dramatically as I have not tried this.
The reason that BFWD appears dirty is that water on an uncoated surface has a different surface tension. It sheets as the water combine easily, increasing the tendency for it to drip off your car. When the water beads up, the weight of that bead/droplet is low so it stays and dries on the car. This is a reason that beading is not the ideal way for a sealant, but the nature of an extremely smooth area is to bead water. |
