Removing the Cats and Resenators
06-25-2007, 07:11 PM | #1 |
66
Rep 2,765
Has anyone done this? is there any sound clips? Ive searched but havent found much. Also does ur Check Engine light come on b/c ur O2 sensors now will read to high of heat resistence and throw a code? I know u can get a extension bung but has anyone had this problem? Ive only seen under the car once a couple weeks ago and believe there r 4 cats? no sure thanks for everyones help
06-25-2007, 07:46 PM | #2 |
184
Rep 1,702
Drives: Audi TTRS, 335is
I think a few guys have done this. Here is a recent thread with some pics from Walked U's car with the resonator deleted and test pipe.
http://www.e90post.com/forums/showthread.php?t=67255 Removing the secondary cats and resonator shouldnt cause any CEL as these are after the 02 sensors. I have heard the sound, and it actually sounds pretty good with the stock mufflers. Maybe WalkedU can chime with a video clip. |
06-25-2007, 08:11 PM | #3 | |
179
Rep 3,125
+1, Ya cats right, you wont throw a CEL. Heres a clip of the exhaust with no post cats / resonator. Just idle with liek 3k revs. I know I took more but cant find them right now. Miss that crappy camera. Hahah fly by The stock mufflers sound really good. Only reason i got rid of mine was to drop a little weight and get a little bit more flow out of it. Ive went through a 2.5 inch exhaust system, and now I have a dual 3 inch system. Ill probably put back my stock mufflers on and run an electric cut out because the drone on the 3 inch duals are annoying in 2-2.5k rpm.
Previous - E90 335i, E82 135i, E89 Z4 3.5SI, Range Rover S/C, Ultra White RCF, Maserati Granturismo
Current Lexus: SMG LC500 performance package Porsche:1973 911E Ferrari 575 SA, 458 Italia |
06-25-2007, 08:28 PM | #5 |
616
Rep 1,420
Where are you getting the electric cut out done??
06-25-2007, 08:31 PM | #6 | |
179
Rep 3,125
There was no room for dual 3 inch. But you just have to customize and get rid of some stuff.
06-25-2007, 08:32 PM | #7 |
168
Rep 2,114
06-25-2007, 08:38 PM | #8 |
179
Rep 3,125
06-25-2007, 09:15 PM | #10 | |
179
Rep 3,125
I had both pipes divorced, but it was kinda raspy up top. So I went back to get the H pipe put on. I have a few more pictures, but i have to find them. Been a long time since my car was close to stock.
06-25-2007, 11:07 PM | #12 |
born to be turbocharged
24
Rep 1,347
the pure straight pipes will cause drone and ricer sound, especially with the cats deleted and straight flow mufflers applied. I'm not sure it's worth of that +3 HP it adds. So yepp, U should use the H pipe and/or the X pipe, if U want to maintain the cruising comfort and differentiate your fine machine from your neighbour's teenager son's ricer civic...
06-25-2007, 11:14 PM | #13 |
Samtaro!
124
Rep 2,601
06-25-2007, 11:23 PM | #14 |
Free taco with stolen base
28
Rep 639
I think that sounds pretty good.
I'm planning on doing a custom dual 2.5in turbo back exhaust using Vibrant metal core race cats with Vibrant straight through mufflers. It shouldn't be too bad and I'm not worried about highway drone. I'm actualy suprised your getting drone at all. My Evo had 3in turbo back exhaust with a testpipe and 3in straight through muffler and I had no highway drone. Adding cats will keep the sound down quite a bit, if it's still too loud I'd add resonators before I changed the design of the exhaust. H-pipes, X-pipes rob power, more than 3hp too, the reason they are quieter is because they hurt flow plain and simple. |
06-25-2007, 11:40 PM | #15 | |
24
Rep 1,347
Vibrant metal core race cats are an excelent choice, they should do the trick and keep your emission tests in order.
How do U handle this? Quote:
06-25-2007, 11:47 PM | #16 | |
179
Rep 3,125
I have a resonator also. ( the resonator is 1 canister but dont share flow) The stock mufflers did a great job in muffling the sound. Also the random crimps in the stock piping helped the noise too. When i removed the resonator and 2ndary cat there was really no drone in the cabin. It was only when i got aftermarket exhaust systems. The 3 series cabin is just hard to get rid of drone @ around 2-2.5k, with aftermarket exhaust and get a good gain in hp
06-25-2007, 11:57 PM | #17 |
179
Rep 3,125
Resonator picture.
06-26-2007, 12:12 AM | #18 | |
28
Rep 639
Here's the thing, unless your in California where they're rediculous with their testing, the average person working at an emission testing station has no idea where or what kind of cats were on the vehicle stock. I've never had a problem with it. As long as it has cats, and the tailpipe is clean, and there's no OBDII codes thrown I've passed. If worse comes to worse, I can put the stock exhaust back on for the testing, which is like every 5 years, or register the car in a county where they have no testing. Since it's never come to that, and I've had nothing but good luck with Vibrant metal cores, I'm not worried about it. Last edited by Cadillac Johnson; 06-26-2007 at 12:38 AM.. |
06-26-2007, 09:56 AM | #19 |
27
Rep 528
Yes several members on here have, including myself. is there any sound clips? See above. Also does ur Check Engine light come on b/c ur O2 sensors now will read to high of heat resistence and throw a code? No. I know u can get a extension bung but has anyone had this problem? You can get an extension if you want, there's no need to however. Ive only seen under the car once a couple weeks ago and believe there r 4 cats? 2 @ the downpipe, 2 in the mid section. |
06-26-2007, 09:57 AM | #20 |
27
Rep 528
06-26-2007, 12:26 PM | #22 | ||
Rep 304
I've never heard of anyone being busted for moving/deleting cats. The only time it might be a problem is if the car was impounded and they were trying to find stuff to pin on you. I deleted the cats on my old car, but doing that extra bit of damage to the enviornment isn't worth it to me these days. A proper race cat should have minimal power losses. Quote:
In turboed applications an X or H pipe only serves for sound right? I wouldn't imagine it would offer much in the way of TQ gains. (as compared to NA) Hmm, well it actually should show a slight loss of power. |
