Its only a matter of time.....keyless theft via ODB programming
05-08-2012, 06:48 PM | #1 |
130
Rep 5,040
http://www.e90post.com/forums/showth...ighlight=theft
http://www.e90post.com/forums/showthread.php?t=688307 Devices are cheap and easy to use so your average neighborhood jack is now a professional criminal... prepare yourselves as this spreads from Europe/UK to North America (if its not here yet) Last edited by bulldog_yyc; 05-08-2012 at 07:37 PM.. |
05-08-2012, 07:24 PM | #2 |
16
Rep 495
Drives: 07 328i
This.... is not good!! How does one disable the obd port?
07 328i
05-08-2012, 08:26 PM | #3 |
411
Rep 3,049
Drives: 2009 BMW 335d
How easy is it to remove the OBD port and simply put it back in when visiting the dealer?
05-08-2012, 09:16 PM | #4 |
130
Rep 5,040
its not hard per say - you could always make a custom connector to it that basically re-maps the pins to a custom mapping that only works with your harness in between to connect to an ODB device
05-08-2012, 10:40 PM | #5 |
112
Rep 2,856
Drives: 2011 335is E93
So wtf do we do to prevent this?
Can it still disable an aftermarket alarm or a satellite type alarm? I guess if they disable per the OBD everything looses power.... Gah! I drive everyday lol I don't have time to be disabling shit. What can we do? |
05-09-2012, 08:27 AM | #6 |
Rep 85
my post from the other thread
http://www.e90post.com/forums/showpo...91&postcount=5 link to pistonheads forum thread http://pistonheads.com/gassing/topic...W+Thefts&mid=0
¯\_(ツ)_/¯
sup son |
05-09-2012, 10:22 AM | #7 |
300
Rep 4,040
Drives: 130i coupé ;)
I propose we use some aluminum to cover the ODP ports.
A 1M in the UK had the port acceded through a blind spot in the OEM alarm. So a cover could cause additional fuss and the extra movements could trigger OEM alarm
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
05-09-2012, 06:22 PM | #8 | |
112
Rep 2,856
There's gotta be an alarm that can sense the OBD port being accessed without the key FOB nearby. This way it kills all power and only works again when FOB is brought next to car. At this point the trigger would default once the car is unlocked. |
05-09-2012, 07:17 PM | #10 |
JBC
35
Rep 310
Drives: E92 AW 335i
What about taking the fuse out? I think another e90post member suggested it.
Cobb Protune (PTF), HFS-4 Meth Kit, DCI, PTF Twin Disk Clutch, Raceland DP's, OCC, F1 Racewerks IC, ER Charge Pipe, Forged DV's, CSL Rep Trunk, Aero lip, Mtech Rear, Custom Ground Control Coilovers, 235/35/19 275/30/19, Quaife LSD, Diff Lockdown Kit, DSS Half Shafts, M3 subframe bushing, M3 Rear Sway Bar
05-09-2012, 07:19 PM | #11 | |
77
Rep 1,208
It won't work because apparently it shares the same fuse as some other features. I'm thinking of using that RFID idea but tapping it into the fuse itself. Then it won't void warranty since it's external to the electrical system and you can physically lock the RFID unit in the glovebox which makes it extremely hard to just bypass. Catch is you'll need to carry a second fob with you but it's basically the kill switch idea. No fob = no power to OBD port. Heck, I could route a few other things in there just to mess with them. (like also disable headlights, power steering, etc...wait bad idea in case your RFID unit dies while you're driving lol). |
05-10-2012, 08:02 PM | #12 | |
112
Rep 2,856
05-10-2012, 09:20 PM | #13 |
130
Rep 5,040
05-23-2012, 10:56 AM | #14 | |
N54 <3
240
Rep 1,558
**Copied and pasted from the UK section on this topic**
E90 335xi|Nav pkg|Sport pkg|Dakota leather|Brushed aluminum trim|MTech kit |
