335i mesh grill
05-08-2012, 01:35 AM | #1 |
Rep 231
335i mesh grill
I just bought these black mesh grills that were supposed to be modified for a 335i, but isn't it blocking the oil cooler? Can someone please chime in on whether these are good to go for a 335i or if I need to modify them.
05-08-2012, 09:04 PM | #3 | |
Rep 231
05-08-2012, 11:27 PM | #4 |
2007 335i E92
44
Rep 624
looks right to me.. oil cooler is on the passenger side which.. only thing i see blocked is the usual half of the drivers side.. unless you're running an intake down to the front bumper, that's the way you want it..
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
05-08-2012, 11:33 PM | #5 |
57
Rep 1,038
The additional oil cooler is on the right-hand side. And that is only if your have one, i.e. if you have the "840 - Increased top-speed limiter" option. (However, if I remember correctly, after some point they started putting that oil cooler there on all cars, regardless of 840.)
In any case, you can easily check where your oil cooler is (and whether it is there at all) by looking into your front passenger-side wheel well. There should be an easily visible air exit grille installed in the well. Through that grille you'll be able to see the oil cooler itself. The left-hand side is supposed to be half-blocked unless you have the Performance Package 2, in which case the blocked part needs to be unblocked to accommodate the extra water cooler air intake. But that's for N55, and you are N54. Last edited by AndreyT; 05-08-2012 at 11:39 PM.. |
05-09-2012, 03:56 AM | #6 | |
Rep 231
05-09-2012, 08:57 AM | #7 |
1086
Rep 1,912
Half blocked grille = driver side. The oil cooler is in the passenger wheel well behind the fender liner if you have one. You don't need to drill holes in the grille.
05-09-2012, 09:00 AM | #8 | |
1086
Rep 1,912
05-09-2012, 10:57 AM | #9 | |
Rep 231
05-09-2012, 11:30 AM | #10 | |
57
Rep 1,038
You mean you have no Sport package of either kind, but you have the cooler in E90? |
