Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Unstable @ highway speeds with rear spacers...(?)
      05-07-2012, 02:36 PM   #1
hankcah
43
Drives: BMW 335i E90
2007 335i  [0.00]
Hey guys,
So I have rear spacers (maybe 12mm) on my 335i and questioning how safe it is...
When going over 80mph on the highway, it feels as if I'm steering a boat rather than a german car anymore. I use to take it up to 110mph, but anything near 80+ I don't feel as safe, especially while changing lanes. Feels as if there is snow on the ground in between lanes.
Is it because I have spacers on the rears and not on the fronts? Should I install front spacers as well to make this awkwardness go away? It has a slight "fishtail" feel when changing lanes on the highway.
Does the camber have that much of an impact in which only the inside of the tires are having less contact when increasing speed?
I also have Yokohama S drives on now. Would it be because of softer sidewalls?
Any thoughts or experiences would be appreciated.
Thanks
Henry
      05-07-2012, 02:37 PM   #2
Lankster
Sigma Alpha Epsilon
38
Drives: 2007 335xi
+1
      05-07-2012, 03:25 PM   #3
BMW_Jaeger
Drives: E90 330D Sport
I would be delighted to hear more on this as was considering spacers myself
      05-07-2012, 04:19 PM   #4
FCobra94
Guest
n/a
Drives:
So, wait...did you put new tires AND spacers on at the same time? If so, it's probably just a "feel" of the new tires sidewall that you aren't used to. Easy way to eliminate the biggest variable though is to just remove the spacers all together and drive it to see if you notice a difference.
      05-07-2012, 05:28 PM   #5
hankcah
43
2007 335i  [0.00]
I put on spacers about halfway through the life of my previous tires. But the "fishtailing" is about the same as on my new tires. No I've put 1000 miles on my new tires so it's not the "newness" of the tires. Where the first 200-300 miles have that weird rubber feel.
Could my already staggered 8.5 rear wheel setup + my 12mm spacer be too much of a setup?
I may go with the front spacers to try and even it out again. But it's so uncomfortable driving sometimes.
      05-07-2012, 05:30 PM   #6
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
63
Drives: Audi SQ5
Would it be the same only at lower speeds? For instance, if you were under 40 mph, but felt nothing over 70 mph? Same setup.
      05-07-2012, 06:53 PM   #7
MRRwheels
48
Drives: E92
if all was perfect before the spacers and the only thing you have done differently is to add the spacers then the problem is ( drum roll....) the spacers.
this happens all the time, spacers are sometimes machined in house and is sometimes a human error in either the machining of the spacers being off by a MM or so.
if you removed them and the drive is back to normal then consider checking those spacers. good luck.
      05-08-2012, 01:24 AM   #8
Hybrid For Life
Germany
79
Drives: Out of Spec
I'd check the torque on the bolts. Just to eliminate any possibly issue with the spacer/wheel not being properly mounted to the hub.
Also what brand are the spacers?
      05-08-2012, 04:35 AM   #9
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
481
Drives: 06 330i 6MT
No such issues with my 12mm rear spacers.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      05-10-2012, 04:45 PM   #10
hankcah
43
2007 335i  [0.00]
I purchased these from Turner Motorsport.
      05-10-2012, 04:50 PM   #11
hankcah
43
2007 335i  [0.00]
My question was more of, is this a known issue with spacers in general or that I just had them on my rears. Of course the problem would go away, if I removed them. But that doesn't solve any thing. I may as well sell the car then, problem solved right? Does it happen all the time?
I love the rear spacers, and I may try another brand, but I don't have any crazy setup/suspension on my car.
      05-11-2012, 12:39 AM   #12
CUTigers
CUTigers's Avatar
24
Drives: 2008 Montego Blue 335i
2008 Lexus IS F  [10.00]
2008 e90 335i  [9.00]
Sell the car. See ya then... People are just trying to help and asking if it's the tires or another factor.
      05-11-2012, 08:18 AM   #13
hankcah
43
2007 335i  [0.00]
Don't take my jokes the wrong way. It's just struck me funny to just get rid of it. if I had that mindset my entire life, I'd have nothing.
      05-11-2012, 11:57 AM   #14
itbettergofast
14
Drives: 2008 BMW 335i
I have ebay 20mm rear spacers and felt no difference from stock.
08 335i E90, AW, jb4 and dci, 20% tint, ER CP,synapse bov ,supreme power perches, cyba tips, BMS WW meth kit, M3 front, BMS catch can, mtech AE, AA downpipes, Big tom IC, kickdown disabled, 15 ohm mod.
      05-11-2012, 12:39 PM   #15
E92335ILAU
METALCRAFTER
E92335ILAU's Avatar
Drives: E92 335i
Are they Hubcentric?
      05-11-2012, 01:20 PM   #16
beskone
beskone's Avatar
73
Drives: LeMans BLue e92 335i LCI
2012 e92 335i LCI  [0.00]
2009 e92 328i  [10.00]
I was running 10mm spacers in front and 12mm in the rear of my e92
No noticeable difference in feel at highway + speeds.
e92 LCI • LeMans BlueSaddle Brown • Bamboo Anthracite • Performance Grilles • CF Performance Spoiler • CF Performance Diffuser • ACS Style Roof Spoiler • LED Interior Lighting • BMS Clutch Stop • BMS Intake • BMS CDV • BMW Performance Exhaust • ST V1 Coilovers • Miro 111 Staggered • More to come!
      05-11-2012, 01:28 PM   #17
michaelalex17
michaelalex17's Avatar
596
Drives: Manual Wagon
why dont u just remove the spacers and see if it fixes the problem?
      05-11-2012, 03:35 PM   #18
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
63
Drives: Audi SQ5
Do you have 10's or 12's. You might be running into a problem if they are 10's and you will need to step up to at least 12's or 15's because of the lip.
      02-05-2013, 08:13 PM   #19
freshwater
freshwater's Avatar
Drives: 2007 335i Jet Black Sports pkg
I know its an Old post but what was the final result, you sold the car or fix the problem.
I am going with Macht Schnell Spacers E90 335i Sports 18mm on the Rear only.
I was thinking it will give more stability to the Car with wider looking wheels in the Rear and may be some under steering.
2007 X5 4.8 | Sport pkg | ZPP | ZCW | ZPS | ZTP | 3rd Row Seat | Entertainment pkg | HUD | Jet Black |Continental Extreme DWS.
      02-06-2013, 12:20 AM   #20
Moony
Moony's Avatar
177
Drives: F80 M3 / F32 435i
2010 328i  [0.00]
I put 10mm front and 15mm tuner motorsports spacers on my 193m staggered setup and everything seemed to be fine. I hit 125mph on the highway to test any fishtailing or any disturbances the other day. Make sure your bolts are secured and you used extended lugnuts
F80 M3
F32 435i - Daily
BMW e92 328i - SOLD /// ST V1 Coilovers /// BMW Performance Exhaust /// OSS Full Blackout /// LCI Tail Lights /// Volk Racing TE37 /// CPS Lip ///
      02-06-2013, 11:52 AM   #21
freshwater
freshwater's Avatar
yep I will get the extended lugnuts with the MS spacers.
      02-06-2013, 05:42 PM   #22
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Exactly. Also, make sure your hub is clean by brushing off any rust. I also recommend driving around for a couple miles and re-torque the lugs. I always do this, with or without spacers.
