Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 19x9 et51 & 19x8.5 et46 on E90 328xi?
      05-05-2012, 08:53 AM   #1
Vic3Driver
Drives: 2007 328xi
Hey folks I saw a sweet deal on some X3 style 191M on my local craigslist listing. I want to jump on it but not sure if we have sufficient room in our wheel well housing and tires for these?
Would bolt these on my 2007 328xi E90
Rear
19x9 et51 (42mm further in vs OEM based on offset calculator)
Front
9x8.5 et46 (31mm further in vs OEM based on offset calculator)
Also what tire combo do you recommend for the above wheels?
Thanks a ton!!
      05-05-2012, 09:23 AM   #2
bmw325i
223
Drives: 2006 BMW 325i
25mm spacer in the rear. 15mm in the front.
      05-05-2012, 10:14 AM   #3
hipnotic
hipnotic's Avatar
149
Drives: e92 335i
2008 335i coupe  [7.00]
wow et 51 I never saw an offset so high.
      05-05-2012, 12:42 PM   #4
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Yes, need spascers like said above, and new smaller tires.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      05-05-2012, 04:21 PM   #5
Vic3Driver
Drives: 2007 328xi
cool thanks for the reply!! So what is the maximum inside clearnance we can get a way with front and rear? Based on the spacers suggest it seems...
For rear it is (42mm-25mm)=17MM inside clearance in rear
For front it is (31mm-15mm)=16MM inside clearance in front
Do the above numbers seem about right when compared to a stock 7" wide wheel setup with et34?
      05-05-2012, 04:25 PM   #6
bmw325i
223
So are you trying to use the smallest spacer possible. The spacers I suggested would look best without rubbing or rolling your fenders.
      05-05-2012, 04:42 PM   #7
edirtaynine
81
Drives: e92
i would get 20mm spacers front and rear. but i personally wouldnt even bother with any wheel that would require me to run 20mm spacers all around. it'd be better to just invest in a set of wheels that fit properly from the start.
      06-08-2012, 09:37 PM   #8
Rainerelliott
Rainerelliott's Avatar
Drives: E90 328xi 2008
Sorry to hijack the post here but I've got a similar predicament:
I happened to come across a guy selling some sick ass OEM E46 powder coated 19x9.5 squared setup (two sets of rear) off his M3 - 255/35/19. As far as I can see, the 19x9.5 ET are 27...my E90 is 34 and 37 - 205/55/16, F & R.
Now, I see this type of question on here a lot, especially lately since I've been looking more. What sort of spacing will I need here for the front and rear on the E90? Is fender rolling necessary?
This is what the wheel offset calculator read:
Rear - 22mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 42mm
Front - 25mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 39mm
Is this ridiculous?
Any help is appreciated!
      06-08-2012, 10:14 PM   #9
bmw325i
223
Is this ridiculous?
You need a 235 tire up front and the rear will be fine with either a 235 to match the front or a 265.
      06-09-2012, 12:47 AM   #10
Rainerelliott
Oh, forgot to mention its an xi. Shouldn't I keep it square?
      06-09-2012, 02:16 AM   #11
bmw325i
223
As long as the diameter is within 1%, you'd be good with 235/265 but if you want to do 235 all around that will work too.
      06-09-2012, 09:43 AM   #12
Rainerelliott
Amazing. So with 235/265 or squared 235 I won't need spacers?
      06-09-2012, 09:45 PM   #13
ZhengHai
ZhengHai's Avatar
240
Drives: E90
Just run 235 all around since the wheels are 9.5 all around. The fronts will be fine but the rear may be tucked in a little. He's running 9.5 et 30 all around.
http://www.e90post.com/forums/showth...ight=rotiforms
      06-09-2012, 10:29 PM   #14
bmw325i
223
If your going with a 235 you can add a 10-12mm spacer but it's not needed.
      06-11-2012, 12:20 AM   #15
Rainerelliott
Well they're 27 ET. What's the possibility of using a 255 all around? Fender rolling?
