ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      06-24-2007, 04:03 AM   #1
epbrown
epbrown's Avatar
60
Drives: BMW M Coupe, Porsche Boxster S
Post on E46Fanatics about remote top open
http://forum.e46fanatics.com/showthread.php?t=483072
That thread has a post from someone that's worked out how to add remote opening to his 330Ci. The other thread he references has a note about how the same instructions should work for the 2003 Z4, with one change. I thought others might be interested.
      07-26-2007, 01:23 AM   #2
magicogar
magicogar's Avatar
Drives: Z4 2.5
I'd be really interested if only my remote would reach farther than 20ft from the car. There's another solution of using a module and hook it up to a cell phone. Then you text message certain phrases and it would open door, roll down/up windows, or do other things.
Another one is an addon to your alarm and register through some satellite company. You call the 1800 Number and it'll do a number of things.
      07-26-2007, 01:47 PM   #3
preilly44
Drives: 04 Z4
I am interested, has anyone here tried this to confirm it will work?
      07-26-2007, 05:57 PM   #4
epbrown
epbrown's Avatar
60
I've got the parts for it but I've been swamped at work and haven't attempted it yet. I'll post the results when I do.
      08-09-2007, 02:57 PM   #5
jaskispyder
Drives: Z4
Anyone do this yet
Any word?
      08-20-2007, 09:59 PM   #6
soeharyo
lettuce
18
Drives: 2003 BMW Z4 3.0i
bump
      08-22-2007, 10:11 PM   #7
epbrown
epbrown's Avatar
60
Wow, reading this reminds me: I work too much! It's almost two months since I planned this project, and still no chance to get to it. Next week I've got some time off leading into the 3 day weekend, so I'll definitely get to this then.
      08-24-2007, 01:16 PM   #8
soeharyo
lettuce
18
take a vacation!
      09-01-2007, 06:32 PM   #9
epbrown
epbrown's Avatar
60
Just a quick update - I wasn't able to finish the project today due to a very late starting and a missing wire crimper, but it looks good. I was able to locate all the wires (which are all the same colors as in the E46 cab write-ups I've read), isolate them, and I've programmed the TR7 module for 2 pulses and 12 seconds - what this means is that after I press "unlock - lock - unlock "- on the remote within 5 seconds, the top will lower for 12 seconds (plenty of time for the Z4 top). Tomorrow I'll need to connect 4 wires and I should be good to go! I want to use my car tonight, so I reassembled everything, but it shouldn't take more than an hour tomorrow.
I did change the project slightly - I decided not to bother with adding the top raising capability, at least for now. I just can't see myself walking away hoping my car finishes closing itself up.
Once I'm done, I'll do a more detailed write-up. There won't be any pictures - one of the glitches I ran into was discover my old digital camera is broken (I also lost my wire crimper somewhere). Confidence is high, though - if this doesn't work tomorrow, odds are I've screwed something up.
      09-01-2007, 09:48 PM   #10
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
can u tell me where the wiring harness is and how to get to it?
oh and u wanna sell me one TR-7 module for cheap? heh
2022 GLE 53 Coupe
      09-01-2007, 10:40 PM   #11
epbrown
epbrown's Avatar
60
The wiring harness is behind and underneath the glove box. You remove the glove box door, then remove the cover underneath that, over the footwell - a couple of Philips head screws (Hmm, actually, I'm not sure you need to remove the door, now that I think of it - I just did). There are 3 connectors going into a white box bolted to the cover - the middle connector is the X253, which is the one you want. It's got 54 pins (3 levels of 18), and you connect the wires from the TR7 as follows:
Down Module
White - pin 20 (unlock signal detect), white and black wire
Green - pin 51 (signals top motor to lower), blue wire (one of several, be careful)
Red - pin 47 (power) red and purple wire
Black - pin 10 (ground) black and brown wire
Really, programming the TR7 was trickier. As for having a spare, sorry, I took them both apart and I'm using the spare to program the one for the car. I'm going for a more compact set-up than the original thread on E46fanatics creates.
      09-03-2007, 09:57 PM   #12
BlackSapphireZ
97
so does it work?
2022 GLE 53 Coupe
      09-04-2007, 07:06 PM   #13
epbrown
epbrown's Avatar
60
Originally Posted by BlackSapphireZ View Post
so does it work?
Sorry, forgot to update this. While programming the TR7 I had a stray wire cross one of my battery contacts, and got that wonderful "pop" sound and the smell of burnt plastic that always bodes well when working with electronics. I'm awaiting delivery of a replacement, but I'm also checking around Chicago stereo shops to see if I can buy one locally. If I can find one, I'll wrap-up the project immediately.
      09-08-2007, 11:49 AM   #14
pemco
ADMIRAL
Drives: 2004 Z4 2.5
I'm very interested in trying this mod. What's a TR7 module. Is it a part from an old triumph?
      09-08-2007, 02:45 PM   #15
epbrown
epbrown's Avatar
60
A TR7 module is, essentially, an excellent opportunity to use Google's search facilities. You can also check that your mouse's ability to click on links is working, using the link in my first post to test.
      09-09-2007, 12:31 AM   #16
BlackSapphireZ
97
didn't work for me
when i do L-U-L, and U-L-U 2 pulses, the units light up accordingly but softtop movement is not there....The light on the factory switch did not turn on
when I do it with the key, I have to turn UNLOCK then Neutral, then unlock again then hold to get the top lowered(vice versa for raising top) and the top moved as designed the light on the factory switch did light up as normal.
i don't know where I messed up or if this even works with the Z4
2022 GLE 53 Coupe
      09-09-2007, 08:17 AM   #17
epbrown
epbrown's Avatar
60
Jin, I saw your post over on E46fanatics.com; I'll reply there.
      09-12-2007, 11:54 AM   #18
preilly44
Drives: 04 Z4
any updates?
      09-12-2007, 01:38 PM   #19
BlackSapphireZ
97
nope..so far i've given up on the project until someone with better knowledge of electricals can figure out what PIN 20 and 22 on E46's are for the Z4.
2022 GLE 53 Coupe
      12-26-2007, 02:04 PM   #20
Santa Fe Roadster
Member
Santa Fe Roadster's Avatar
Drives: 2003 Z4 2.5 Sport
Has anyone attempting this project? It sounds interesting & I'd appreacate hearing if anyone has achieved successful results!
BMW rear spoiler - de-badged - MTEC HIDs (DEFECTIVE) - XENESIS high beams & fogs - shadowline front grill - 20% tint - keyhole plugs - Roadster Solutions acrylic wind deflector - LeatherZ center console & door arm rests - Parrot 3100 bluetooth - USA SPEC IPod integration - Xenon interior lighting
      12-26-2007, 03:23 PM   #21
BlackSapphireZ
97
no
2022 GLE 53 Coupe
      04-25-2008, 12:09 PM   #22
jaskispyder
Drives: Z4
any luck?
curious if this worked
Search this Thread:
Advanced Search
zpost
