Stock Map
06-23-2007, 05:11 PM | #1 |
28
Rep 321
Stock Map
Hey
Im also seeing a boost of about 9-10 psi at 4800m no where close to 12-14. How do i t get hold of a stock map to load and dyno the car then load 1.45 and dyno again? All my posts are never answered. Also want to know how good the vushnu catback exhaust is, any of you guys know? |
06-23-2007, 05:15 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
How and in what gear are you measuring boost? With the PROcede software?
FWIW, if you're not hitting the boost target, you will know it because a trouble code/engine light will be triggered. If there is no light, everything on the boost side of things is just fine. The only other thing I can think of is octane. I don't know what kind of fuel you have down there in South Africa but if it isn't sufficient, the factory ECU will lower the boost targets considerably to protect the engine. Shiv |
06-23-2007, 07:06 PM | #3 | ||
Rep 6
I also tried asking for this on vishnu tuning forums but nobody answered me. Thanks in advance Bye PS: Quote:
I'm loving how my PROcede works but don't you think my turbos are getting to much pressure? |
06-23-2007, 08:37 PM | #4 |
1737
Rep 17,960
Drives: A Lot
That 18+psi boost reading was after you lifted off the throttle. This is a normal pressure spike ad is what the bypass valves try to relieve. Remember that the MAP sensor used to read boost isn't in the intake manifold (which wouldn't see these pressure spikes because it is on the other side of the throttle body) but in the intercooler pipe instead.
I can post up a stock map within the next few days. Just testing out some stuff right now. shiv |
