Mpg dropped tremendously
04-28-2012, 08:24 AM | #1 |
Rep 104
I don't know where to post this but I was wondering if there any solution...
2 weeks ago I went to took my 07 328xi for my first maintenance, got air filter/tire rotation well at least that what it say on the paper... The mpg monitor been staying accurate from 19.2mph for like 5k miles, but it been dropping a lot to 16.1 and 16.2 The 328xi is like 17/25 but what the hell I drive freeway more then urban |
04-28-2012, 08:32 AM | #2 |
1706
Rep 14,829
That happened to me after the free maint ended, and I changed my air filter with a mahle knecht. If I were you I'd get a new air filter over the web, and put it in yourself. If your mileage goes back up, you know not to go to that dealership again.
The other possibility is you haven't got enough experience (data) to make your readings reliable. When mine dropped, I drove the same route to work for 3 weeks. Then I decided it was time to do something and my lowered mpgs were valid... |
04-28-2012, 10:54 AM | #3 | |
124
Rep 5,627
Tom |
04-28-2012, 12:39 PM | #4 |
104
Rep 1,529
damn my car started to feel a little funny and my mpg dropped hard for some reason, but damn you guys are getting crappy mpgs lol.
when im cruising on the highway goin 60 my mpg was around 35, but then i started to run it hard and something happened and when i cruised at 60 last night and it was consistently at like 30-31. so i went ahead and switched maps on my cobb and seems like it did the trick but we will see...cuirsed this morning at 60 and got around 35 mpg again.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
04-28-2012, 12:40 PM | #5 |
104
Rep 1,529
oh yeah and i got some weird codes too something like h3100, hh2a87, p2f4a, and the normal p2aaf
could someone tell me what the first 3 codes are? i searched for them but didnt get a true fix for these only the definition.
04-28-2012, 01:10 PM | #6 |
1918
Rep 13,116
I wonder if they screwed up you MAF Sensor.
I wonder if they screwed up your MAF Sensor.
I would take that air filter out and have a look at it and or clean the MAF Sensor and reseat the connector to it. Also do you reset your mpg's at each gas tank or was that cumulative number if you don't I would wait awhile before getting exited as its and average. |
04-28-2012, 01:12 PM | #7 |
196
Rep 6,136
04-28-2012, 01:38 PM | #8 | |
104
Rep 1,529
anyway when i do cruise at 70 my mpg is around 32 and at 80 its around 30 and at 100 its like 24 lol
04-28-2012, 03:51 PM | #9 | |
1435
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-28-2012, 04:23 PM | #10 |
Rep 104
Well I have pumped 3x time each time is like 11 gallon around 55$-60$ from where I lived...zzz i never reseted anything other then when my low tire pressure turn on... And my check engine light soon has been on... I find to ignore it because I took to BMW dealership and they say they gotta do system update and asked for like 300$... Other then that all I got info
04-28-2012, 07:33 PM | #11 | |
45
Rep 1,754
04-28-2012, 07:42 PM | #12 | |
138
Rep 2,731
Are you sure you are looking at the right menu? One is average speed, the other is average MPG. Best thing you can do is this.... get on the interstate, get to 55 or something legal and hit cruise. While cruising reset the average MPG meter. it will show your current MPG and keep updating. After a few minutes of driving on flat ground, while on cruise, you will have an idea of your MPG. If you hit the gas or slow down and speed up or go up or down a hill it will fuck it up. |
04-28-2012, 10:10 PM | #13 |
38
Rep 823
Depends honestly on alot really, My 330i runs 33-34mpg on highway (55-65mph depending on speed limits). I had over 1/4 tank left on 380mile trip.
04-28-2012, 10:11 PM | #14 | |
38
Rep 823
04-28-2012, 11:52 PM | #16 |
Rep 104
Yeah I meant mpg of course not 19.2mph my bad...damn 600 miles all highway I assume idk what's going on... If anyone know a local BMW service that gives free diagnostic in local Houston tx area I would really appreciate it
04-29-2012, 12:36 AM | #17 |
138
Rep 2,731
yea all highway, driving from up north to FL and back.
anyway. you said the shop did the air filter. since you are having a problem it is not unrealistic to think they fucked something up and unmetered air is getting past the MAF (mass airflow sensor) somehow. when you change the air filter (not the same as the microfilter) you unhook intake parts, if they aren't connected right you have a leak. the mass airflow sensor measures the air getting sucked in the car so that the proper ratio of fuel is injected for optimal performance and gas mileage. if air is sneaking in after the MAF, then it isn't measured and the ratio is off, and your mileage sucks. take the intake apart and reassemble, make sure the filter is in right, maybe clean the MAF with an aerosol MAF cleaner from autozone. then put it all back together. maybe when they did the filter they dropped the part of the airbox with the MAF. something had to of happened. |
