Continental DWS tires in warm temps and hiway speeds
04-25-2012, 06:24 PM | #1 |
Hates Speed Limits
111
Rep 2,589
So it has been 80ish degrees in the afternoons on the way home from work and my DWS's feel a little soft on the highway at 80+. On squirts of the throttle to pass they feel really squishy especially above 100 (just wanted to test them a tad ) but I also have my camber/toe adjusted (still within bmw specs) to allow for better tire wear but it does reduce handling a bit. Is that more of the cause or is it the tires being really soft sidewalled? They feel alright in the mornings and feel really good when its cold outside. I have the tires up +2 in the front and +3 in the rear psi but that was done in the winter, should I adjust it for the cold? Please advise. I drive 80 miles a day, 75 of it highway, so I needed a long-life tire and needed to keep them longer life. Just trying to figure out what the deal is. The tires are great in the wet, just not quite as good when its warm out. Tire wear looks brand new still with just over 3k on them.
E92 Space Gray 335i - COBB, BMW Performance Exhaust (stock tips), style 230 rims, LUX H8 AE's
04-26-2012, 08:29 PM | #2 |
Hates Speed Limits
111
Rep 2,589
Update: I checked my tire psi when I got home and my fronts were 46psi and my rear were 48. Dropped that down to 38-39 front and 41-42 rear. Hopefully that helps. I last put air in them when avg temps were in the 40's. Hopefully in the colder mornings they dont drop too low on pressure.
04-27-2012, 08:23 AM | #3 |
Guest
Rep n/a
Drives:
You have to check pressures when they're cold; not after a long drive...check them in the morning BEFORE you leave for work and then adjust from there. Also, I have the same tires as well and yes, they do get more "squishy" the warmer it gets outside. As you stated; it's a trade off given that it's a long-life tire and also because the sidewall isn't as stiff as summer tires or even some other high performance all season's in comparison.
04-27-2012, 11:58 AM | #4 | |
Moderator
369
Rep 4,745
Spot on.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
04-27-2012, 05:54 PM | #5 | |
Hates Speed Limits
111
Rep 2,589
I wish they wouldnt be so 'squishy' but yea....its a trade off. I love their wet performance and they were great in the two times we had 'light' snow when I had them on. Thanks for the replies guys! They did feel better today since they were over inflated before.
04-27-2012, 08:13 PM | #7 |
BimmerPost Supporting Vendor
2042
Rep 25,989
What I normally do is fill up my tires a bit extra on my drive home from work. First thing in the morning, I'd just purge them until they're at spec. But yes, the tires do have a softer sidewall which is why they might feel a little squishy especially when it's warm out.
VMR|Wheels | 714.442.7916 |
04-28-2012, 02:22 PM | #8 | |
Hates Speed Limits
111
Rep 2,589
