New set of VMRs, Need your spacer recommendations!
04-25-2012, 01:49 AM | #1 |
28
Rep 234
Drives: 2018 M3 Avus Blue
Just recently bought a set of VMR VB3's but currently not liking the front offset, not enough poke! Would you guys recommend running a 5mm or 10mm hubcentric spacer up front? I want to achieve a flush look...
Specs: Fronts: 19x8.5 +40 235/35/r19 Rears: 19x9.5 +33 265/30/r19
Current: 2018 F80 M3 Competition | Avus Blue 1 of 93 | Revivify Ceramic Coated
Current: 2011 E92 M3 | Alpine White | Active Auto Gen 2 Exhaust | IND Cosmetics | Comp Wheels Previous: 2018 F80 M3 Executive | Yas Marina Blue | M Performance Exhaust | FI Downpipes | AA EL Mid Pipes | BM3 Stage 2 | BBS RT88 Wheels | Jordan Tuned on E85| |
04-25-2012, 07:13 AM | #2 |
Rainbow Racer
1008
Rep 2,539
I would measure your clearance to make sure (so you don't rub with your drop), but when my brother used a 8.5 +40et, we measured at least another 10mm before a flush look is achieved on his E92 with H&R springs.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
04-25-2012, 09:12 AM | #3 |
A family of bimmers
2748
Rep 7,742
7mm with a hub extender?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
04-25-2012, 11:35 AM | #4 |
Ex-Diesel Driver
63
Rep 2,000
If you were buying new wheels, why didn't you order in the more aggressive offset?
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
04-25-2012, 11:48 AM | #5 |
28
Rep 234
for vmr vb3s they only offer a +40 or +20 offset for 19x8.5's and IMO +20 is a bit too crazy for a lci
04-25-2012, 12:58 PM | #6 |
Rep 240
Drives: 2007 335i sedan
Im currently running vb3's 19x8.5 et40 up front with a 12mm spacer lowered on eibachs with 235/35 falkens fits perfect the rear is 19x10 et38 with 10mm spacer 275/35 with slight fender roll and i think i can actually run 285 falkens though hope this helps.
04-25-2012, 01:10 PM | #7 |
143
Rep 2,284
+20 offset would've been perfect from personal experience. For now, you can probably put a 15mm spacer up front and it will give you semi flushed look. For the rears, put a 10mm spacer and you should be golden.
04-25-2012, 02:17 PM | #10 |
Rep 240
On my previous post i meant 275/30 in the rear. My bad!
04-25-2012, 02:17 PM | #11 |
143
Rep 2,284
04-25-2012, 02:31 PM | #12 |
28
Rep 234
kool thanks guys for your feedback! Anth ask burger too hook it up!!
04-25-2012, 06:57 PM | #14 |
Ex-Diesel Driver
63
Rep 2,000
I have a set of 15mm with bolts for you - click my sig.
05-16-2012, 11:31 PM | #18 |
28
Rep 234
