Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > are my fenders already rolled?
      04-23-2012, 09:32 PM   #1
ahwest
Drives: E90 LCI
recently bought my e92 and try to figure out if the fenders are already rolled?
      04-23-2012, 11:50 PM   #2
jdhart73
jdhart73's Avatar
Drives: 2008 BMW 335i
Maybe with a baseball bat. They are cracked and look like they were not done correctly if indeed they are rolled. I would say someone attempted it with the wrong tools, not all is lost though as you should be able to heat them up and roll them flat.
      05-04-2012, 11:18 AM   #3
ahwest
Drives: E90 LCI
so I test fitted 10mm spacers for the rear... it's rubbing a little bit but it seems that it's only rubbing on the fender lining not the fender itself... there's already a hole on the fender lining due to rubbing...does anyone have the same experience? is there anything I can do to eliminate that?
      05-04-2012, 12:26 PM   #4
edirtaynine
81
Drives: e92
the rear fenders come "rolled" like that already. its basically a super conservative roll. you can go check out a brand new one with 0 miles at the dealer to see for yourself.
      05-04-2012, 01:51 PM   #5
Ghost170
Ghost170's Avatar
89
Drives: VIP Sport 335!
^ +1
07 E92 335!
AA AE GP HR LC M3 KW BMS BMW LUX CYBA STRI WORK HELIX MTECH LSWEEE(Wavetrac)!
      05-04-2012, 02:04 PM   #6
ahwest
Drives: E90 LCI
how do you guys fix the rubbing lining issue?
      05-04-2012, 02:10 PM   #7
#Tee
#Tee's Avatar
557
Drives: yes
You let the carpet lining rub itself til its all busted up or cut it yourself. You go low n flush you gotta do whatever it takes. This is just a small obstacle.
You can follow my builds on IG: Tee212
      05-04-2012, 04:13 PM   #8
ahwest
Drives: E90 LCI
thanks for the input! gotta do some cutting tonite!
      05-04-2012, 05:39 PM   #9
Andrewe92
enthusiast
Andrewe92's Avatar
117
Drives: 2011 e92 lci 335xi
Yeah def cut ..
