Pic request e90 18in vmr 701
04-26-2012, 07:41 AM | #3 |
163
Rep 2,823
Yes it is possible.
About front If the car is on stock struts with lowering springs/stock springs. 9.5 et 35 is probably highest offset to begin with anything higher than that you will hit struts inside.Around et35-30 is good. If you want more aggressive then you need lower offset. I have seen et20-22 front. (Coilovers need more room) Easiest fit will be 235 wide tyre. Here is couple examples Et27-30 9.5 front http://www.e90post.com/forums/showthread.php?t=670323 http://www.stanceworks.com/forums/sh...ad.php?t=19860 Et33 9.5 front http://www.e90post.com/forums/showthread.php?t=347791 http://www.e90post.com/forums/showth...ght=19x11+et33 http://www.e90post.com/forums/showth...ght=19x11+et33 Et35 9.5 front http://www.e90post.com/forums/showthread.php?t=478069 You can go wider front tyres but then you need to adjust camber etc. Here is more talk about 9.5 front with differend tyre sizes http://www.e90post.com/forums/showthread.php?t=665682 http://www.e90post.com/forums/showth...28#post5840028 And you can go more aggressive. Then you might need to adjust camber, roll your fenders and use more stretched tyres 9.5 et 22 front http://www.e90post.com/forums/showpo...11&postcount=7 http://www.e90post.com/forums/showthread.php?t=597536 http://www.e90post.com/forums/showpo...24&postcount=4 I have 07 BMW E90pre lci and my setup is going to be 18x9.5 allround with front offset 35 and rear 22 tyres 235/40/18 front and rear. All of those links i found just by forum search/google. When i was looking info about my setup. Thats my desicion, but you can use different rear offset with different tyre size. There is so many setups. This is what 9.5 et22 rear looks like with 235/40/18 http://www.e90post.com/forums/showthread.php?t=444796 Hope this helps. |
