E90 335is / 135i DCT Swap with 335i
04-23-2012, 09:29 AM | #1 |
66
Rep 276
Has anyone done this swap?
Its kind of disappointing that BMW NA didn't offer the DCT on the 335i sedan yet they do offer it on the 135i. I cannot afford the e90 M3 but i wanted the DCT transmission and the 335is is 2 door only. I currently own a e36 and was looking to get a 335i this summer but do not want the standard auto. Am I out of luck? Thanks. |
04-24-2012, 02:22 AM | #3 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Usually a sign that no one has done it. The transmission alone is $8300 on Tischer. Kinda falls under the "just get one with it" category.
The i8 needs a V8 amirite?
04-24-2012, 08:52 AM | #4 | |
66
Rep 276
Thanks for the info. No e90 for me I guess |
04-24-2012, 09:03 AM | #5 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
You should be able to do, have no idea how much it will cost, it because BMW sells the 335i with the DCT in other parts of the world. Would be a case of rounding up the factory swap parts & a 7DCT from a wrecking yard to keep the cost down.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
04-24-2012, 11:01 PM | #6 | |
66
Rep 276
Would you need parts from a 335i sedan from out of the country or would the 335is parts work from a US car? |
04-29-2012, 06:38 AM | #9 |
76
Rep 911
How would you programm this into a car? I'm afraid thats going to be extremly hard.. maybe with a 335is ECU swap... but still
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
04-29-2012, 08:07 AM | #10 |
Rep 194
This is a awesome question, I'm curious myself. Kinda put to much into this 335 already. Lol this standard auto is kinda getting boring. I'm going to look into this more in depth
04-29-2012, 09:11 AM | #12 |
90
Rep 632
Will it cheaper to swap a manual?
My plan is swap a manual when AT is gone... |
04-29-2012, 10:32 AM | #13 |
36
Rep 1,329
04-29-2012, 11:45 AM | #14 | |
76
Rep 911
The thing is that you need to find a BMW dealer that would like to join you on this journey. They have to help you with updating your software.
04-29-2012, 12:15 PM | #16 | |
90
Rep 632
If lucky enough, a salvage manual car sit in junk yard will be a great choice, just take the ECU and trans. BTW, I don't think dealer would let us access to the software. |
04-29-2012, 12:16 PM | #17 |
90
Rep 632
04-29-2012, 03:57 PM | #18 |
813
Rep 3,974
The DCT is the main reason I wouldn't get the 335is. The steptronic is better suited to hard launches without the worry of worn clutch plates. That and the fact I wish you could get a new steptronic sedan with a N54.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
04-29-2012, 11:19 PM | #19 | |
3433
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
The auto transmission has come a looooooooooooooong way since your e36. You can drive in two different auto modes...D and DS (sport), you can shift manually from the lever or the steering wheel paddles. And most importantly it can hold up to a lot more abuse than the DCT.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
04-30-2012, 02:45 AM | #20 | |
66
Rep 276
Ill have to do some more research. Thanks. |
04-30-2012, 10:50 AM | #21 |
Rep 41
as far as I know you can get reinforced clutch for the dct, and it should be the same dct as on e92 m3, they are holding 450-500whp fine, but on the superchargers setups which has less torque than turbo
05-13-2013, 10:21 AM | #22 | |
44
Rep 318
1)DCT 2)EGS module (transmission ECU) belonging to a DCT 3)Programming and coding software (INPA/WINKFP/TOOL32) Not sure yet if a new EGS mdoule would be needed since a used module would have the old car's VIN assigned to it. I know for sure that you can't overwrite a VIN on a DME (engine ECU), I'd have to check if it's the same for a EGS. So, my guess is you would have to install the new transmission, install the EGS module, assign your vehicle VIN to the new EGS module, update VO (vehicle options list) so that the DCT is recognized by the car and finally code the EGS module so it reads the right values from the new transmission. Sounds complicated but once you learn how to code and program it turns out to be pretty simple. This sounds like a challenging swap but not at all difficult.
Airhead//Caffeine//Junky//Beemer//Fan
