Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Which RE050A RFT?
      04-22-2012, 07:27 PM   #1
Northern335i
Drives: 2019 330i xdrive sedan
Which RE050A RFT?
I have a 335i sedan, sport package, that came stock with RE050A RFTs. The rear tires (255/35R18) need replacing and I've been searching TireRack for them. Unfortunately, 3 different models come up. There's an RE050A RFT and two types of RE050A I RFTs; the latter has a Y and W option, and different UTQG numbers. What's the difference between the models? Why is the traction grade on the W version of the I better (AA) than the Y (A)? Which of the W rated tires should I be buying? Thanks in advance!
      04-23-2012, 11:26 AM   #2
Northern335i
Follow-up from Tire Rack
I emailed this question to Gary at Tire Rack and this is the reply I got:
According to our database, the original equipment version that would match the front tires would be the W speed rated version 140 A A. Bridgestone has technical notes for the newer 140 AA A version that states that they are not to be mixed with the older version of the tire. Unfortunately Bridgestone doesn't tell us the exact differences between them but my best guess would be a difference in the rubber compound that allowed the tire to score higher in the wet braking test (this is what the A and AA refer to). I would also guess that because the tires have different compounds, Bridgestone does not recommend mixing them.
The higher speed rated Y version would also not be recommended to mix with the original W rated version up front.
To put it simply, get the 140 A A version to match the original front tires. If you're replacing all four and can wait for the newer version you could get those instead.
Tags
335i, e90, re050a, re050a i, rft
