My $10 Fix for Non-iDrive Messy Wires... AUX & Charger
04-18-2012, 10:47 PM | #1 |
Kumar
71
Rep 747
Basically drilled a hole in the little compartment and put in a rubber grommet and fed the wires through the center console and under the trim, through the grommet, and viola.
You can drill the hole yourself, but I took the compartment to ACE Hardware and they charged me a mere 7 bucks to drill the hole and center it. The grommet was like 45 cents. Clean and quick fix instead of running wires across the top. Hope it helps someone Enjoy! Last edited by DesiRoc; 04-27-2012 at 01:20 PM.. |
04-19-2012, 09:43 AM | #4 |
2069
Rep 5,373
This is what you need to get!
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
04-19-2012, 12:43 PM | #6 | |
Rep 54
now i just have to plug on thing in (lazy) |
04-19-2012, 12:54 PM | #7 | |
Kumar
71
Rep 747
However, A customer review said that the cable won't work if you've updated your iPhone to 5.1 or above. You'll get the "device not supported for charging" box. Anyone know if this is accurate? |
04-19-2012, 02:39 PM | #8 |
2069
Rep 5,373
Mine works no prob.
04-23-2012, 09:10 AM | #10 |
2069
Rep 5,373
Thank you, I did your grommet thingy yesterday. Much better.
04-23-2012, 03:16 PM | #12 | |
40
Rep 413
04-23-2012, 03:31 PM | #13 | |
2069
Rep 5,373
You're welcome.
04-23-2012, 08:49 PM | #14 | |
Kumar
71
Rep 747
04-27-2012, 09:39 AM | #15 | |
40
Rep 413
04-27-2012, 09:43 AM | #16 |
Daily Driven!
188
Rep 2,516
Drives: BMW 335i
Clean instal
04-27-2012, 01:33 PM | #19 |
46
Rep 730
Awesome guess i got an answer to my messy cord out the side. Thanks for the information, make life easier
04-28-2012, 10:27 PM | #20 | |
13
Rep 107
This may be a stupid question, but how did you pass the ipod cable thru the grommet hole since the connectors are bigger than the hole? |
04-29-2012, 04:37 AM | #21 | |
Kumar
71
Rep 747
It might be easier to drill a 3/4 inch hole that the USB side will fit through, and then feed it from the outside of the hole into the trim and through the center console from the bottom. |
04-29-2012, 11:55 AM | #22 |
Autobot
Rep 454
Drives: E90 325i Auto~NO~Go
Great tip. Purchased the adapter and cable. Will be performing the mod once received. THANKS!
