335i sensors for datalogging
06-19-2007, 01:57 PM | #1 |
Moderator
270
Rep 4,481
Hi
Two forum members have already or are planning to install additional sensors: 1) EGT sensor: One has it installed already for a Zeitronix setup. Is it installed in the turbo-manifold and how about the installation ? Method, efforts ? 2) Terry with his LM-1 widband plans to install it in place of the post-cat o2-sensor(s ?). How would the ECU behave with such a setup ? Do you plan to emulate the post-cat o2's for the ECU ? Eugen |
06-19-2007, 02:07 PM | #2 | |
96
Rep 2,587
The LM1 can go in the existing bung, you can add a new bung, or you can use an adaptor to shove it in the tailpipe (looks ghetto driving around but works). I'm going to put it in an existing bung, zip-tie the secondary o2 sensor, and ignore the resulting code. Once I'm done tuning I'll pull the LM1 out. You can emulate the secondary o2 sensor and keep it in long term but I'm too lazy to find the right connectors and don't want to cut any wires. |
06-19-2007, 02:24 PM | #3 | |
274
Rep 6,510
06-19-2007, 02:27 PM | #4 | |
Moderator
270
Rep 4,481
On CATALYTIC CONVERTER equipped vehicles: Install the oxygen sensor’s bung upstream from the catalytic converter (a bung and plug is included in the LM-1/LC-1 kit). Any decent muffler or exhaust shop can do this for you. The wideband oxygen sensor is then installed into the bung to take a reading. (Insert the plug into the bung when not in use). The bung must be installed in the exhaust pipe at the side or on top, NOT on the bottom of the exhaust pipe. Best position is between 10:00 and 2:00 position. |
06-19-2007, 02:36 PM | #5 |
born to be turbocharged
24
Rep 1,347
yepp, afaik the primary lambdas are responsible for the main AF measurement, the secondary's are mostly for checking the cat function and backup... no? So for testing tuning etc U should use/replace the primary sensors
06-19-2007, 03:41 PM | #6 |
96
Rep 2,587
I'll use the post-cat o2 sensor, the pre-cat is used for closed loop and would be a bad idea. It's best to put the wideband in front of the cat but at the end of the day I'm only worried about the delta so no biggie.
06-19-2007, 03:53 PM | #7 |
38
Rep 762
Putting it in the post cat o2 sensor bung will only give you real results at wide open throttle. Part throttle or idle will show really lean ratios because the cat is "cleaning" up the bad exhaust gases.
