Diesel Engines
11-03-2005, 01:00 PM | #1 |
Addict
203
Rep 2,074
Diesel Engines
Okay, So I've been happily driving my 320d for almost 5 months now, and since the new car "whoopies" are wearing off, me and my car are getting better aquainted.
I've spent alot of tonight reading a FAQ on TDI's which speaks mainly of VW TDI's using direct injection. My car uses common rail technology if I understand correctly... the TDI FAQ also mentions that diesel engines don't have spark plugs? That's rather interesting... Can any diesel heads shed some light on the diesel engine, or point me towards a website that does? (Particularly BMW's and not VW's) Out of interest, the site I am reading is tdiclub.com/TDIFAQ Thanks.... Another interesting point the site mentions... Diesels engines do NOT heat up if left to idle.... who knew? Is this true for the BMW? I want to know more about my car... |
11-03-2005, 01:01 PM | #2 |
///M Specialist
556
Rep 1,497
What type of information are you looking for?
2023 M340ix my Daily Driver
G83 M4CV, F80 M3 CS, E30 M3, Z8, other various BMW's Ferrari F8 |
11-03-2005, 01:09 PM | #3 | |
Addict
203
Rep 2,074
How the pistons works (apparently on compressed air and no spark plug?) Intercoolers? Turbo charges? |
11-03-2005, 01:12 PM | #4 |
Do Not Taunt Zen Driver.
12
Rep 466
11-03-2005, 04:30 PM | #5 |
1311
Rep 10,185
You have a Turbo Charger, with variable vanes
You have a Intercooler You dont have spark plugs, diesel self ignites due to high compession, but you hvae glowplugs to help when engine is cold You have a diesel catalitic converter Your fuel pressure is about 1,600bar A BMW 4 Cylinder Diesel Engine |
11-03-2005, 06:22 PM | #6 |
119
Rep 2,909
Diesel motors are compression motors that don't require spark plugs. Since the motor compresses the air so much (so hot) with aid of a VNT turbo, all that the hot air needs is some fuel to ignite it. Diesel motors don't have such violent explosions during combustion like traditional petrol motors, but rather a softer flame-up. This is why diesel motors can't rev super high. The glow plugs that you hear about are only needed when the motor is cold.
11-04-2005, 01:35 AM | #7 | |
Addict
203
Rep 2,074
Now....with this common rail thing? Is that how the fuel is sent to the chambers? What about direct injection? (Does the BMW use direct injection in the diesels)? |
11-04-2005, 02:21 AM | #8 | |
1311
Rep 10,185
What it means is the fuel is injected directly into the cylinder, and not into the air intake manfold just before the valves like the older engines do. Here is a bit on Common rail technology http://www.swedespeed.com/news/publi...inter_272.html Your car has 2nd Generation common rail as far as I know |
11-15-2005, 06:17 AM | #9 | |
Enthusiast
466
Rep 1,791
Drives: F87 M2 / F31 330d
Garage List 2004 E46 BMW M3 [0.00]
2017 F87 BMW M2 [10.00] 2013 F31 330d Touring [9.50] 2009 E89 Z4 Sdrive 30i [9.00] 1989 E30 320is 2-door [10.00] 1986 E28 M535i [9.00] |
You wont notice that since every modern diesel has built in an additional (auxiliary) heater. My dad had a 2001 530d (navi professional) without the optional auxiliary heater with remote (€ 1200). A buddy BMW service technician told us, every BMW diesel has the additional heater built in which can be upgraded as fully stand-alone auxiliary heater. And the best: It was only a software update! Now you can fully operate it from the navi screen, you just have no remote. So why does the heater cost extra € 1xxx on every BMW, either petrol or not? |
11-16-2005, 05:32 AM | #10 |
Rep 2
Dante, I'm curious to know more about this aux heater that's part of all diesel engines, and can just be programmed. I'm getting an E90 diesel in the UK soon, and here they don't offer the aux heating option. (Don't understand why not as it's pretty cold ).
So if it's just a programming issue, could I still get it. Or is that option dealer fitted? If so, I could get it fitted at a German/Dutch dealer at a later date. |
11-16-2005, 10:30 AM | #11 | |
Enthusiast
466
Rep 1,791
Hmm, not sure about e90. Which engine do you get? And are you going to order nav/i-drive? Because if not, I dont know how to operate the aux heater since you have no remote. But I will talk to my friend over that issue, maybe he knows... If he confirms I will start a new thread on this. |
12-02-2005, 07:35 PM | #12 | |
46
Rep 292
03-05-2006, 12:03 PM | #13 |
Rep 126
The advantage of common rail diesel injection over direct injection is the fact that you have less engine noise and reduces exhaust emissions even further. The diesel engine also has a much higher compression ratio compared to petrol engines. Diesel 17:1 Petrol 11:1. That is why some diesel cars needs oil replacement every 7500 km. Depending of the type of oil they use and the quality of diesel used they push up the service interval. The diesel engine weirs out the oil quicker because of the high compression and the high heat of the turbo charger. That is why the diesel engine oil is always very black, compared to petrol engine oil. It is not good to drive a diesel engine very hard and then just switch it off. You can damage the turbo charger if you do that (all that heat and then no cooling). The turbo also has variable vanes controlled by the engine management system. The BMW 320d is one of the most advanced, most powerful and most economical diesel engines in its size.
