N54 High Precision Injection (HPI) limits
06-19-2007, 09:16 AM | #1 |
born to be turbocharged
24
Rep 1,347
I was wondering about the fuel delivery capacity of the HPI system. Made a little utfg research on it. Before posting any question, here are some facts:
- BMW uses piezo direct injection made by Siemens VDO (yepp, I guess the name is familiar to the 335i owners and fans). It makes a complete setup with their HP fuel pump (that's why it's not that easy to replace) - Some technical data on piezo injectors:
- Technical data high-pressure pump:
U can d/l the complete SiemensVDO brochure from here. Sorry about the storage, but for unknown reason I was not able to attach the file here. Now my questions:
06-19-2007, 10:09 AM | #2 |
62
Rep 1,476
We need more data on the max flow the pump can handle.
170kg/h = 170 liters/hour = 45 gal/hour @ 3500 rpms. Seems strange that they give a flow with an rpm and depending on the number of cyclinders. Do they mean it can flow 90 gal/hour at 7000 rpms? if so the fuel pump should be good for many upgrades to come. |
06-19-2007, 01:27 PM | #3 |
24
Rep 1,347
imho it's strange that they specify flow values in weight units not volume, but I hoped to pull the attention of somebody wiser like me. I'll try to email them for further specification.
06-19-2007, 01:49 PM | #4 |
24
Rep 1,347
Regarding the weight measure used, maybe we could use 1m3=737.22kg @ 60F for vehicle fuel, but it's strange anyway.
I sent them an email. I am really curious about the answer, if they answer at all. |
06-19-2007, 04:36 PM | #5 |
62
Rep 1,476
06-19-2007, 07:29 PM | #6 |
24
Rep 1,347
sorry, not a native english speaking - dis- what? If U mean disrespect or something against U - nope, I mistyped or U took it the bad way.
"I hoped to pull the attention of somebody wiser like me... ...to take these numbers, understand them, do the math or just simply comment." |
06-20-2007, 09:18 AM | #7 |
14
Rep 1,137
As far as I understand the fuel pump capacity is not going to be a restriction. Even if the capacity was 170 liters/hour it would be good for 500hp. But as you pointed out one kg is much more than one liter, so fuel pump capacity should be more than enough.
06-20-2007, 09:39 AM | #8 | |
14
Rep 1,137
06-20-2007, 10:02 AM | #10 | |
24
Rep 1,347
35g/s * 3600 = 126 kg/h / 0.74kg/l = 170 l/h
the veyron burns s/t like 5l/min, 300l/h (full perf, unreal), so yess, it should be enuff for 500+ HP (@ crank). If it is for one piston only, it is a mistake, too much to be true. See quote: Quote:
06-20-2007, 10:35 AM | #11 |
14
Rep 1,137
Or you can just plug some numbers here:
http://www.slowgt.com/Calc1.htm#FPHP |
06-20-2007, 11:17 AM | #12 |
62
Rep 1,476
I found the following info in a fuel injection basics manual that came with my AEM manual.
OK now for my disclaimer.... I don't know if the same rules apply,the BMW system uses the newest direct injection technology which I'm sure AEM did not account for when they wrote this. ************************************************** ***** Fuel Pump Sizing To achieve proper fuel delivery, you must select the right fuel pump for your vehicle. In most cases, where the engine has been modified only with “bolt on” performance items, there is rarely need for a larger fuel pump or larger injectors. Vehicle manufacturers typically design a “safety factor” into the fuel pump to accommodate the deterioration of the fuel system over time. This safety factor is intended to compensate for a fuel filter that is nearing the end its life, or for deposits in the injector orifice. Our research has revealed that generally there is about a 15%-20% oversize in most factory fuel pumps. If the engine is enhanced via forced induction or nitrous oxide, the stock fuel pump is inadequate. If the engine’s power is increased more than 15-20% fuel delivery must increase as a factor of the power gain. The way to determine the proper-size fuel pump is based on the desired brake specific fuel consumption (BSFC) of the engine. This term refers to how much fuel in pounds per hour (pph) the engine consumes per horsepower and is a measure of the efficiency of the engine. It is a useful term in determining the total fuel requirement of the engine. On vehicles equipped with forced induction or nitrous oxide, higher BSFC’s are required as an added measure of safety to prevent detonation or high combustion chamber temperatures. Below is a guide of BSFC’s with standard CR that AEM uses for various engines that run on gasoline: • Naturally Aspirated engines have a BSFC of .48 to .50 • Forced Induction engines have a BSFC of .65 to .68 Methanol (alcohol) powered engines require twice the amount of fuel so the BSFC’s are doubled. Calculating the total fuel requirement of an engine requires simple equations that we outline in the following section. You must know how much power the engine is anticipated to make and we recommend that you guess on the high end. The fuel requirement will be determined in pounds per hour of fuel flow. Since most pumps are rated in gallons/hour you must know the weight of your fuel/gallon. (The vast majority of gasoline based fuels run at 7.25 lbs./gallon.) The equations to determine your fuel requirement is as follows: • (Power x BSFC) x (1 + Safety Margin) = pounds/hour • Pounds/hour / 7.25 = gallons/hour. An example of this equation is: • 500 hp gasoline engine using moderate boost with a 30% safety margin • (500 x .625) x 1.30 = 406.25 lbs./hr. • 406lbs/7.25 = 56 gallons/hour. • If the pump that is being considered is rated in liters per hour, use the conversion factor of 3.785l/gallon. The pump described above would be rated at 56 gallons x 3.785 liters = 211.96 liters/hour. In the fuel pump sizing, always use a safety margin greater than 20%. |
06-20-2007, 11:39 AM | #13 |
14
Rep 1,137
AEM is pretty cautious.
I would guess that those BSFC figures are a bit pessimistic considering that N54 should be highly efficient. Also the safety factor is on the safe side considering that "The safety factor is intended to compensate for a fuel filter that is nearing the end its life, or for deposits in the injector orifice." which is not the case with our new vehicles for some time. |
